 Post subject: Bug - Slow jumping on bad sectors when WD decryption is on !
PostPosted: December 14th, 2019, 13:30
Another BUG !
Will it ever be solved by MRT team?
Not expecting that they'll fix this in next 1 or 2 or either 5 years, at least i aspect it will be solved in the next 10 years :roll: (SARCASM).
Yep, when all hard drives will be still diffused as Commodors 64 and VHS.
This bug consist of slow jumpings on bad sectors when cloning in DE with WD decryption turned on, even at very low timings set.
I made this video to be more clear:
https://youtu.be/GRM3hWcReC8
PC3000 behavies correctly when on fly decryption is turned on, MRT does jump bad sectors fastly only when decryption is off.
Please MRT, fix it soon as possible, i'm taking months for cloning this drive.
GRRRRRR :twisted:
My firmware database:
 Post subject: Re: Bug - Slow jumping on bad sectors when WD decryption is
PostPosted: December 14th, 2019, 18:02
Why did you leave modules 30 and 411 disabled?
VEXUS Data Recovery
PostPosted: December 14th, 2019, 20:09
just testing
PostPosted: December 18th, 2019, 11:06
Boss ,
Have You tried this on 2141 version ?
PostPosted: December 18th, 2019, 13:18
Where is the bug? Do you mean yellow unread blocks?
Did you try to remove fast reading thick . Also can change skip sector count when meet bad sector
Sexy Womans from your town
PostPosted: December 18th, 2019, 14:22
Amarbir[CDR-Labs] wrote:
Boss ,
I'm using 2130 version.
I haven't update yet to last version and i don't want to unless is sure that this bug got solved in last version.
Amarbir, do u have last version?
Have u tried to clone bad surface drive with wd decryption turn on?
PostPosted: December 18th, 2019, 23:19
Boss ,
Well,
I have 3 units of MRT .I can try but i use this tool as my secondary line of defence ,Primary in PC3K
