 Post subject: Windows tool like dd_rescue
PostPosted: January 19th, 2020, 16:09
I was wondering if there is some programm for Windows which work like dd_rescue? In combination with the USB stabilizer or Guardonix could that be quite handy to do multi-pass imaging. Thatfor the tool would need to keep track of the already imaged sectors and fill the gaps in an 2nd pass with a longer timeout.
Is there something that can do this trick?
 Post subject: Re: Windows tool like dd_rescue
PostPosted: January 19th, 2020, 21:35
I've tested the deepspsar usb stabilizer with ddrescue running under cygwin in windows and it works fine.
PostPosted: January 20th, 2020, 2:49
OK thanks, that is a good tip! Was not thinking on cygwin...
PostPosted: January 20th, 2020, 4:59
Maybe Klennet disk imager https://www.klennet.com/imager/default.aspx?
PostPosted: January 20th, 2020, 5:38
Arch Stanton wrote:
... interesting but as it looks that tool does the passes automatically one after another. That would not really help in that case. I need to finnish one pass, have the tool wait till I change the settings on the USB stabilizer and start then manually a 2nd pass.
Anyway - thanks for the tip.
Users browsing this forum: No registered users and 126 guests
