 Post subject: Req : HTS541010B7E610 Firmware + ROM [0012000T]
PostPosted: May 20th, 2020, 12:23
Does anyone Have Module 11.rpm for This Exact Palmer model sold as HGST ,A very interesting this i noticed is that model no 11.rpm has different size for same Rom Version ,So instead of a general palmer does anyone have resources for this HGST
PS : I get a Error If i try uploading Mod 11.rpm as size differs
 Post subject: Re: Req : HTS541010B7E610 Firmware + ROM [0012000T]
PostPosted: May 21st, 2020, 15:00
what's the size of your 11?
PostPosted: August 31st, 2020, 17:45
Hi Amarbir,
Did you ever find this? I'm in a similar sounding situation where I think a loader will help, but the 0012000T loader for Western Digital branded drive doesn't work.
-Brian
Hi Amarbir,
-Brian
PostPosted: August 31st, 2020, 18:23
Could we see some of these loaders? Perhaps there is some slack space which could be truncated? This kind of trick works for other brands, eg Samsung.
PostPosted: September 1st, 2020, 2:17
The 0012000T I'm trying (that doesn't work) is the one here: https://files.hddguru.com/download/PC-3 ... ty/Palmer/
Possible loader isn't working due to another issue (like incompatible heads or platter damage), but getting a loader from this model would help narrow down the problem.
PostPosted: September 1st, 2020, 4:50
Please provide this information from your disk
>ROM version............................. : 02.1AP
>ROM F/W version......................... : 0002000P
>Overlay F/W version..................... : 02.1BP
>Servo F/W version....................... : 01.3C
0012000T this is not the actual firmware version, it is only an entry in the 4F module (this entry is not always compatible with the firmware version)
Mikippp
PostPosted: September 1st, 2020, 14:29
I don't see any slack space, so truncation is not feasible.
PostPosted: September 2nd, 2020, 1:29
ROM version............................. : 02.20P
ROM F/W version......................... : 0012000T
Overlay F/W version..................... : 02.20P
Servo F/W version....................... : B1.3K
ROM + modules here: https://slack-files.com/T041AF3B4-F019X ... 96076459e3
