 Post subject: Problem with Seagate 4000GB Hard Drive
PostPosted: May 24th, 2020, 17:59
Hi, all. The above hard drive has stopped working. I took it out of its box to feel whether it is spinning or any other symptoms, but could not find any except I can hear the motor starts spinning and then shut down, the computer does not recognize it.
My knowledge is very limited as far as Hard Disks are concerned, however I took out the HD Board and power it to check the continuity of circuit and have recorded the voltage I found on it (Photo attached).
Is it possible to diagnose from the voltage reading which I have recorded on the Photo ? If desired I can take more readings of it. Thanks.
 Post subject: Re: Problem with Seagate 4000GB Hard Drive
PostPosted: May 24th, 2020, 19:12
It sounds like an internal fault, not PCB related.
BTW, your PSU is badly regulated. Your are measuring 13.8V where one would expect to see +12V.
PostPosted: May 25th, 2020, 1:55
+1 not an PCB related fault.
If you care about data contact trusted member pcimage https://forum.hddguru.com/memberlist.ph ... ile&u=5866
They can help you to get your data back http://pcimage.co.uk/
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: May 25th, 2020, 4:59
99.99% nothing to do with PCB.
Spin up/ down is symptom of head and/or media damage.
Nothing DIY you can do expect make it 10x worse, sorry!
Users browsing this forum: Google [Bot] and 164 guests
