 Post subject: WD nasware 4TB mycloud
PostPosted: May 29th, 2020, 5:32
Hi guys I have swap head and data recovered from this drive but the folder inside are inaccessible, i have used linux to see the contents and it's possibile to see only file in public folder, I think the folder are protected with a password in nas. Exist a system to open and read content from this hard drive ? tks
 Post subject: Re: WD nasware 4TB mycloud
PostPosted: May 29th, 2020, 6:05
Better to clone or image the drive first,,,
U have to use https://www.ufsexplorer.com/ufs-explore ... covery.php
Version 7
To get the Data in folders name ,
PostPosted: May 29th, 2020, 6:22
Version 7
Yes I have tried but in the folder protected in NAS i see unable to display folder content with ufsexplorer
PostPosted: May 29th, 2020, 6:48
Can you post a photo?
Is it ufs7?
PostPosted: May 29th, 2020, 7:11
Is it ufs7?
yes
PostPosted: May 29th, 2020, 7:22
and this with 7
PostPosted: May 29th, 2020, 8:29
Is it cloned drive?
PostPosted: May 29th, 2020, 10:51
H13 wrote:
Is it cloned drive?
yes it's cloned with mrt
PostPosted: June 4th, 2020, 8:35
Scan the clone with DMDE
data recovery Poland
PostPosted: June 4th, 2020, 9:05
Which version of MyCloud is it? can you post pic of pcb (from the enclosure)? That folder tree does not look like the one i remember, which had folder structure in db...
If it is simply ext4, try scanning the whole drive and look at Lost Files folder or whatever it is called in UFS
PostPosted: June 4th, 2020, 10:09
@pepe
The MyCloud which saves as DB is different,,, look @ the image the OP attached it has folder names/structure
the one you mean saves in another way...
:idea:
My best guess here (missing/damaged head)
PostPosted: June 4th, 2020, 15:11
yeah, i think this one is an older version.
OP said it has been cloned, he didn't mention if it was a partial clone..
PostPosted: June 4th, 2020, 17:08
Hi guys tks for support I have solved the issue. I have connected the original disk in mycloud box but after starting the Led flashing red, I have opened the administration page and insert the password, inside the page the storage area are empty, I have inserted the clones disk inside mycloud and I have same situation , I have connected the original disk in mycloud and the clones disk in usb box connected to mycloud and nothing , in administration page storage are empty and usb device cannot be mounted . At the last I have powered off the unit remove the usb disk and powered the mycloud with origial disk the Led green flashing many times and after this change to red I have opened the administration page and mycloud say me to change administration password, I have leaved blank password and after save I have try to mount the disk in my computer and voila, now work, the red folder are full and working . I don't know why this but work , and I have cloned again the original to new disk and no problem . Tks guys
Users browsing this forum: Google [Bot] and 76 guests
