Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: Cutting head from Rosewood
PostPosted: July 14th, 2020, 4:32
I think it is because it is designed so. They could have do it by shingles as well probably.
BTW, i think it is done by zones on rosewood, they have more zones therfore they are less wide.
PostPosted: July 14th, 2020, 8:26
I think it has something like 3,3GB on each head so it's definitely worth recovering.
odzyskiwanie danych
PostPosted: July 14th, 2020, 13:53
definitely, but the amount is not constant, varies within a pretty large interval
PostPosted: July 14th, 2020, 13:54
I have done many, many Rosewoods with media damage on one surface by snipping the culprit head. Of course there’s more to it than just the “snip” :-)
H1 and H2 on 2Tb ones are a little awkward so they could be bent as Pepe says, but I prefer to snip.
PostPosted: July 14th, 2020, 14:01
Good to know :-)
PostPosted: July 14th, 2020, 14:48
Like 50% from a single platter 1Tb rosewood in a “toughened” LaCie drive, including (luckily) 75% of the photo shoot the client was after! Top surface was scrubbed clean :-(
PostPosted: July 14th, 2020, 14:58
lucky chap :)
PostPosted: July 14th, 2020, 15:02
Do you edit the adaptives to reduce the head count? I suppose you also edit the head map?
PostPosted: July 14th, 2020, 16:06
That’s right
PostPosted: July 14th, 2020, 16:26
That’s right
I wonder if different FW versions of Rosewoods act differently.
