 Post subject: PCB BSY Samsung 2,5" ST1000LM024 HN-M101MBB
PostPosted: August 18th, 2020, 11:39
I got a Samsung ST1000LM024 when connected to PC3K, it show nothing on terminal. The motor spin, no bad noise but BSY DRD DWF DSC DRQ CRR IDX are solid green and all other are solid red.
It looks like PCB issue, I clean it with alcool, I don't see anything wrong.
Ïs there a typical chip I should check on Samsung PCB ?
 Post subject: Re: PCB BSY Samsung 2,5" ST1000LM024 HN-M101MBB
PostPosted: August 18th, 2020, 14:35
The PCB in the photo is not from this disk
The PCB is from the Seagate 5400.3 drive
Mikippp
PostPosted: August 18th, 2020, 16:02
Thank you Mikippp
This PCB really looks like genuine on this disk, Model also looks like Seagate ST1000LM024. Is there a partnership between them ?
PostPosted: August 18th, 2020, 16:05
It's a fake. Look how the label is misaligned, plus you can see the old gum residue.
The manufacture date on the label is 2017.09. The date codes on the chips are 649 and 652. That's weeks 49 and 52 of 2016. That's a difference of 9 months.
PostPosted: August 18th, 2020, 16:24
PostPosted: August 18th, 2020, 16:58
Thank you Fzabkar, so this is a "copied" drive of orginial Samsung drive ? Is there a chance to recover data ?
PostPosted: August 18th, 2020, 17:08
definitely a fake. A really poor one. Look, there's a residue of an old sticker UNDER the P/N sticker :)
And some glue remnants as well.
PostPosted: August 18th, 2020, 17:09
It's a Seagate 5400.3. Use your Seagate tool.
PostPosted: August 18th, 2020, 17:11
Thank you for confirming what I already wrote.
PostPosted: August 18th, 2020, 17:14
I think that the date codes should be weeks 49 and 52 of 2006. That's a difference of 11 years.
PostPosted: August 18th, 2020, 17:20
ouch, i missed that, sorry :oops:
PostPosted: August 19th, 2020, 3:56
Thank you guys, very helpfull. Last question, what's the purpose of doing those Fake drive ? I don't get it.
PostPosted: August 19th, 2020, 10:14
money, pure and simple
PostPosted: August 19th, 2020, 13:43
Mikippp
Hi ,
Extremely Good Observation ,BTW samstown please read all the manuals properly and try some stuff on donors then start data recovery on clients cases
PostPosted: September 4th, 2020, 4:18
Ok, so data recovered using Seagate tool. Capacity of 80 GB,The customer will not buy on Wish anymore. Thank you Mikippp, Fzabkar and Pepe for your answer.
Users browsing this forum: Bing [Bot] and 62 guests
