 Post subject: Loader for WD Palmer WD10SPZX-24Z10T0
PostPosted: August 29th, 2020, 9:14
I need ressources for WD Palmer WD10SPZX-24Z10T0.
I tried fessources from hddguru sharinf files and hddsurgery database, unfortunately, it shows me
Permanent ovl (11) data uploading Device Error Detected: "VSC ERR OFF TOO LARGE"
The drive is locked. I used an unlock PCB to unlock it. it was recgnized and could read SA modules. Then by mistake I erased module 32. now drive run in kernel mode.
Thank yo in advance for your help.
Kind regrds
 Post subject: Re: Loader for WD Palmer WD10SPZX-24Z10T0
PostPosted: August 30th, 2020, 12:37
Anyone who have this ressource is willing to help :roll:
PostPosted: August 30th, 2020, 21:56
Can't you use the 22Z10T0 resources at hddsurgery.com?
https://firmware.hddsurgery.com/index.php?manufacturer=Western%20Digital&family=Palmer
PostPosted: August 31st, 2020, 1:31
Dear fzabkar,
Thank you for your help.
I tried all the ressources of hddsurgery database. they are not compatible (with PC3000 confirmation)
It says module 11 it too large.
PostPosted: August 31st, 2020, 3:16
What microcode OVLY 11 do you need?
PostPosted: August 31st, 2020, 4:06
And why not use the drives own mod 11 from when you read SA modules ?
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: August 31st, 2020, 5:02
because I stopped the backup of SA (because it was very slow) and empty the module 32. :roll:
PostPosted: August 31st, 2020, 5:07
Model: WD10SPZX-24Z10T0
FW: 01-01A01
Ideally, modules 01, 02, 11
PostPosted: August 31st, 2020, 5:44
FW: 01-01A01
This is not enough. Please post fw microcode version.
PostPosted: August 31st, 2020, 5:49
Here the requested info:
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 1024 Kb
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 161 862
Module 02 access........................ : Granted
ROM Modules:
ROM version............................. : 02.1AP
ROM F/W version......................... : 0002000T
Overlay F/W version..................... : 02.1AP
Servo F/W version....................... : 01.3C
PostPosted: August 31st, 2020, 6:10
>ROM Modules:
>ROM F/W version......................... : 0002000P
>Overlay F/W version..................... : 02.1BP
Mikippp
11.zip [718.9 KiB]
Downloaded 655 times
PostPosted: August 31st, 2020, 7:35
Thank you for your help Mikippp
Now, it shows this:
Cache ovl(10) data uploading............ : Ok
Permanent ovl (11) data uploading Device Error Detected: "HOST DEBUGSTOP OCCURRED"
Users browsing this forum: No registered users and 66 guests
