 Post subject: ROM dump identification
PostPosted: September 8th, 2020, 16:24
Seagate drive with a suspect non original ROM chip. Have dumped ROM but not sure how I can identify what its come from, if its not original. Can't see any useful plain text in hex viewer.
20200908_210242_FLASH_25040.zip [433.48 KiB]
Downloaded 526 times
 Post subject: Re: ROM dump identification
PostPosted: September 8th, 2020, 16:45
The ROM is corrupt.
https://www.seagate.com/au/en/support/warranty-and-replacements/
Model Number ST9500325AS
SerialNumber 6VEFA67M
0007D590  00 00 36 56 45 46 41 36 37 4D C0 BA 01 00 00 00  ..6VEFA67MÀº....
PostPosted: September 8th, 2020, 17:05
Thank you! Yes so that's a completely different model to what it's supposed to be so indeed non original ROM.
It's a company up the road from me that if you reject their repair quote they sabotage your hard drive.... 3rd case I have had in off the back of them in the last 12 months. The first one I noticed they had replaced the ROM with a MOSFET.
PostPosted: September 8th, 2020, 17:12
I have attached the adaptives.
Edit: Our posts crossed, so it appears that the adaptives are not required.
adaptives.7z [9.85 KiB]
Downloaded 1298 times
PostPosted: September 9th, 2020, 4:07
what's the model of the drive?
I might be able to help with it, however, i think recovering from this situation will not be cheaper than the original quote... :(
PostPosted: September 9th, 2020, 9:31
The ROM is corrupt.
Hi friend .
What utility do you use to analyze Seagate F3 roms?
A few days ago I found your utility for WD wdROMv12.exe and it is fantastic.
Thank you
PostPosted: September 9th, 2020, 15:24
Version 15 computes the checksum of the more recent boot blocks, whereas v12 does not:
http://www.users.on.net/~fzabkar/FreeBasic_W32/WD/
WDnewROM analyses the latest WD ROMs (new native WD architecture).
This is the tool for Seagate ROMs (written by @E123):
http://www.hddoracle.com/viewtopic.php?f=22&t=2534
PostPosted: September 9th, 2020, 16:07
Thank you very much for your fantastic profits.
And thanks also to @E123 for the seagate one.
PostPosted: September 20th, 2020, 6:14
Hey fzabkar,
Sorry if this is off-topic as I'm a bit new. I have a ROM dump of an OEM Seagate 10K 2.5" SAS Drive. Is there a way to generate an LOD file from this? I have compared the LOD header from other oem firmwares of similar Seagate drives, so I understand that the first 250k (roughly) bytes deal with the LOD header. Any advice is appreciated on how to go about this. I can't PM you yet, so I thought I'd ask here since Seagate dumps are being discussed. I know how to modify the hex code, but not sure how to read the dump. I can upload it for you if that helps. Thanks for your time and help. If you need any further information from me, let me know.
PostPosted: September 20th, 2020, 23:14
@E123 has written a LOD editor for Seagate SATA drives. I don't know if he has done the same for SAS. However, the LOD file, at least for early SATA models, normally consists of 4 overlays which live in the SA rather than the ROM.
Users browsing this forum: No registered users and 142 guests
