 Post subject: Seagate ST3500418AS
PostPosted: September 15th, 2020, 1:13
Hi I have got such Seagate with damaged ROM (I think so) with such terminal outputs, am I right? Is this case recoverable? Attached ROM file
SEA-3 Yeti Boot ROM 2.0 (12/06/7)
Copyright Seagate 2007
Boot Cmds:
DS
AP <addr>
WT <data>
RD
GO
TE
BR <divisor>
BT
WW
RET
ROM.zip [705.86 KiB]
Downloaded 438 times
https://jkrecovery.pl/
 Post subject: Re: Seagate ST3500418AS
PostPosted: September 15th, 2020, 8:46
Check rom integrity with F3romExplorer
http://www.hddoracle.com/viewtopic.php?p=18531#p18531
Checksum seem to be corrupted on segment DL_CFW, try to correct it.
Correct checksum for that segment should be 6DEF.
My firmware database:
PostPosted: September 15th, 2020, 9:07
wait a second...
Why the rom file you have posted is double sized?
Rom size of this drve should be 512 Kb, your is 1 MB.
PostPosted: September 15th, 2020, 9:22
There 2 exact copies of same rom inside the .bin file.
PostPosted: September 18th, 2020, 10:07
Sorry for long response time, PC3K gives me 1024 image of ROM from this drive, programmer gives 512KB.
PostPosted: September 18th, 2020, 10:09
I get also such message:
Parsing segment....... CFW
WARNING! Segment whole space check sum is invalid!
Unpacked data length mismatch!
WARNING! Segment used space check sum is invalid!
PostPosted: September 18th, 2020, 10:18
I have write ROM again after repair but when I read it again still get same size 1024kb and same problems - like writing by terminal don't work properlly
PostPosted: September 18th, 2020, 12:12
What's written on rom chip case?
Is it a SPI rom such as W25P40 or W25P80 ?
If is 80 (1 MB) then very likely someone has swapped it with wrong chip, because on this drive should be 40 (512 Kb)
In this case, solder a proper 512 Kb spi rom on the pcb and write rom code with corrected checksum, or just get a valid donor pcb (with 512 Kb spi rom) and write rom code with corrected checksum.
PostPosted: September 18th, 2020, 13:10
case solved by a help of You michael chiklis, thanks
PostPosted: September 18th, 2020, 13:20
you welcome!
:wink:
Users browsing this forum: No registered users and 141 guests
