 Post subject: New Rosewood Terminal Error
PostPosted: September 30th, 2020, 14:14
Anyone seen this error on a Rosewood before?
It obviously has head issues as well.
But the LargeShock error?
LrgShock  happens before seek
LargeShock @ 00005781
RECOV Servo Op=0095 Resp=0005
 Post subject: Re: New Rosewood Terminal Error
PostPosted: September 30th, 2020, 14:51
Does it feel like it's vibrating than usual?
PostPosted: September 30th, 2020, 15:26
Spins up normally with no additional vibration, but the drive continually seeks.
Client said he dropped the drive but caught it before it hit the floor.
There are new heads in the drive.
PostPosted: October 2nd, 2020, 3:21
Hi!
What's the model number?
Maybe the platters are misaligned.
PostPosted: October 2nd, 2020, 10:58
saltwater wrote:
Hi!
The drive had significant media damage.
I guess it was so severe it was affecting the balance maybe.
PostPosted: October 2nd, 2020, 14:03
...or the media damage cause that, the HSA can't reads proper servo signal.
PostPosted: October 2nd, 2020, 15:14
Have you tried a different PCB? Perhaps the shock sensor(s) on the PCB have been damaged.
PostPosted: October 2nd, 2020, 15:16
Or something bad with the shock sensor crystal
PostPosted: October 2nd, 2020, 17:03
We did change heads and PCB, but still get the same result.
PostPosted: October 2nd, 2020, 20:08
I don't know what kind of mistake it is, I'm trying to reach a mutual non-aggression agreement with these units.... I don't know if the error is directly related to this, but I bet that SA is degraded or simply doesn't exist anymore (at least a part of it).
