 Post subject: St1000DM000 with partial sector access problem
PostPosted: October 8th, 2020, 9:35
I have a St1000DM000 which will image ok, with some sporadic bads sectors, then hit a point and can't read any sector beyond it. Definitely not just on one head, can't read any sector from that point. So I'm assuming I need to regenerate the translator. Terminal read out is
ExecuteSpinRequest
FAIL Op=0100 Resp=0005
FAIL Op=0900 Resp=0005
FAIL Op=0600 Resp=0005
FAIL Op=0055 Resp=0005
(P) SATA Reset
RAW OFF
PASS
RW: Error processing Performance Parameter File: 203C
I've checked the non resident GList and it is not empty. Is
2- m0,6,2,,,,,22
still the correct command to use?
Thanks!
 Post subject: Re: St1000DM000 with partial sector access problem
PostPosted: October 9th, 2020, 3:53
Nope. can you show V40 log?
PostPosted: October 9th, 2020, 10:15
F3 T>V40
Nonresident GList 1F entries returned
Total entries available: 1F
PBA Len Flags Phy Cyl Hd PhySctr SFI
5D8078E 2E 0 26E0 2 138 AE51D
715FCB2 2E 0 2F38 2 814 ADA19
7C7600D 2D 0 33DA 2 26B ADA95
8B862EE 2D 0 39EA 2 332 AA752
8B9A1F3 2D 0 3A09 2 75F AA7BB
99BBDDD 2C 0 4048 2 8E9 B2E58
99BC630 26 0 4047 2 714 B2DEF
99BD6D7 2C 0 4045 2 36B B2F09
99BDF2A 26 0 4044 2 196 B2E58
99BF9F8 2D 0 4042 2 814 B2D86
99C0A99 2C 0 4040 2 465 B23DA
99C12F2 2D 0 403F 2 296 B2DEF
99C1B45 2D 0 403E 2 C1 B2D86
99C2DBA 33 0 403D 2 90E B2257
99C3E1C 2D 0 403B 2 520 AA7BB
99C46B4 33 0 403A 2 390 B22C0
99C4F0E 2C 0 4039 2 1C2 B2F09
99C5774 20 0 4038 2 0 B5096
99C618F D 0 4038 2 A1B B391E
99C69D6 2C 0 4037 2 83A B2329
99C7229 33 0 4036 2 665 B22C0
99C7A83 26 0 4035 2 497 B2F09
99C82DC 26 0 4034 2 2C8 B391E
99C8B2F 2D 0 4033 2 F3 B38B5
99CBEF8 20 0 402E 2 1F4 B3A38
A58F6AB 20 0 4512 2 8EF AC948
A58F6DD 26 0 4512 2 921 B22C0
DF9601C 32 0 5D4E 2 190 AB404
DF96054 20 0 5D4E 2 1C8 B17FA
E451985 32 0 5F83 2 E1 B18AB
19FD57C3 2A 0 B07D 2 7C2 AB0AF
Users browsing this forum: Google [Bot] and 53 guests
