 Post subject: HM160HC not spinning, BUSY forever
PostPosted: June 6th, 2009, 16:39
Dear all,
I have a Samsung HM160HC which is not spinning, and is showing BUSY right after powered on, and stays like that forever.
Trying it with a similar board, it does spin up, so I assume it's a PCB fault, so I try to repair it.
I've compared all resistors, diodes, capacitors, etc with a multimeter to the known good one, and found no significant difference anywhere. The three components I could not test are:
-Marvell 88i6723S-BCT1 (no pinout, and BGA)
-TI TLS2502B (no pinout)
-the white SOT23-6(?) packaged component with a marking like "bd."(?) on it (next to the Marvell chip), as I don't know what it is
As I'm getting at least a BUSY, can I assume that the Marvell processor is working?
If so, how come it's not writing anything about the error on the serial port (not a single byte)?
Could you please advise where my reasoning is wrong?
Thanks in advance,
Peter
 Post subject: Re: HM160HC not spinning, BUSY forever
PostPosted: June 6th, 2009, 17:00
kovacsp wrote:
Dear all,
Thanks in advance,
Peter
The samsung's pcb is sensitive for exchanging.
Maybe the HDA is assembled with different brand heads, or another version/brand of preamp, or just simple the ROM is not compatible with the MC in the platters.
But as you know allready, the diagnose is free @ my lab, and if i have right, this case is cheap or relatively cheap. :wink:
Janos
PostPosted: June 6th, 2009, 17:16
Hi Janos,
thanks for your reply.
I'm not trying to make it work with the other PCB, as I know it's far from being a good donor. I'm trying to repair the original PCB, so the components should not be incompatible with each other (unless somebody else swapped it before).
Best regards,
Peter
PostPosted: June 6th, 2009, 17:29
kovacsp wrote:
Hi Janos,
Best regards,
Peter
if you want to repair the old pcb, i can imagine 3 options:
1. VCD bad
2. some fuse is blown
3. ROM corruption in MCU (i have no @ hand, i am not sure it is internal or external, but if i have right, it is internal)
Maybe helps....
Janos
+1 extra: this is not the original pcb
PostPosted: June 6th, 2009, 17:34
1. VCD bad
Yes it's internal. Is there any way to check if the ROM is corrupted?
Thanks,
Peter
PostPosted: June 6th, 2009, 17:38
without proper tool, no. :(
You can only close out the other cases.
If everithing is good in the pcb, but the drive is still busy, than it is ROM corruption.
PostPosted: June 6th, 2009, 17:58
Janos, thank you very much!
Peter
PostPosted: June 6th, 2009, 18:20
Damn I am so far... I should have diagnosed it in seconds...
PostPosted: June 7th, 2009, 1:20
Did you mean method of swap...?
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
PostPosted: June 7th, 2009, 1:51
No. Head check, Rom check and eventually fix it, mc (=sa) check and fix, etc. Need to open only for surface check (scored platter)
PostPosted: June 7th, 2009, 7:22
What tool do you use to check and fix the ROM inside the Marvell processor? I mean do you have access to Marvell develpoment tools, or you have a different method (own method)?
Thanks,
Peter
PostPosted: June 7th, 2009, 9:09
Own / proprietary. Note: sometimes the marvell chip fail and it's game over... New pcb req'd.
PostPosted: June 7th, 2009, 17:04
Thanks for your help! So I can start looking for an exact matching PCB..
PostPosted: August 27th, 2009, 6:12
I have several Samsung HM160HC drives I decided to play around with. I found it interesting to read that these drives have a serial interface and now I would like to listen to it. Can one of you tell me to which pads I need to connect? Any additional information (about the possibilities one has with the serial interface [how to interpret the information the drive sends, terminal commands, etc...] or about the drive itself) would also be great.
Guspi
PostPosted: August 27th, 2009, 7:43
kovacsp wrote:
Hi Janos,
Best regards,
Peter
Have you swapped the TI motor driver IC? I have seen them fail in this model.
http://www.datasaversllc.com
PostPosted: October 31st, 2020, 12:42
Hello, somebody know how I can accesr to ROM in The MCU for HDD Samsung HM121HC, on the chip 88i6723S ? Thank you
PostPosted: November 3rd, 2020, 4:31
reading or writing?
Users browsing this forum: ccc and 256 guests
