Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2, 3  Next
 Post subject: What tools support WD/HGST Black and Red Drives?
PostPosted: December 23rd, 2020, 13:52
What tools work on WD/HGST Black and Red Drives such as wd4005fzbx, wd2003fzex, wd6003fzbx, wd80efax, qd100ezaz, etc...?
 Post subject: Re: What tools support WD/HGST Black and Red Drives?
PostPosted: December 24th, 2020, 1:33
The WD6003FZBX is a rebadged HGST (WWN = 5000CCA...):
https://i.ebayimg.com/images/g/tdAAAOSwYMFfKta9/s-l1600.jpg
The R/N is US7SAN6T0 which is used by several Ultrastar SATA models:
https://fccid.io/MSIP-REM-WDT-US7SAN6T0
HUS726T4TALE600, WD4003FYYZ-01TF7X0, WD4003VYYZ-02GP3X0, WD4003FYYZ-01TF7B0, WD4003FYYZ-31TF7X0, WD4003FRYZ-01F0DX0, WD4005FZBX-00K5WB0, HUS726T4TALA6L1, HUS726T6TALN6L1, WD6003FZBX-00K5WX0, HUS726T4TALE6L1, HUS726T6TALN601, WD6003FFBX-68MU3N0
WD's warranty checker URL identifies it as ...
WD6003FZBX-00K5WB0
WDVL6
7200
256M
SATA3
6GB/S
6.0 TB
8HD
STD
HGST
https://support-en.wd.com/app/warrantystatus
PostPosted: December 24th, 2020, 7:21
You are correct fzabkar. I believe all of the models I listed are HGST(now WD, they are labeled WD) drives. The wd100ezaz is a 10TB helium drive, I think it is SMR too.
I have 1 to 3 of each of these drives that are basically all doing the same thing. They spin up and click a few times, keep spinning and are recognized in PC BIOS but are not recognized in windows xp computer management. WD Marvel sees it, but of course can not do anything with it. I am needing to know what tools I need to attempt to work on these. Do I need a hardware/software solution (pc-3000) or will some of the software based programs work with them?
PostPosted: December 24th, 2020, 7:52
MHDD sees it, but when I init drive it says "recal fail."
Hdd Supertool sees it in ATA and SCSI passthrough and it will Identify it. Smart Info fails. If I try to Scan Device it, it gives all errors. I have not tried Direct mode yet, because even though I am having it boot off USB stick with no other hard drives connected but it, the program warns that the drive is available to OS and exits. Before I went through the trouble of "hiding it," I wanted to confirm if the program would work on the drive.
PostPosted: December 24th, 2020, 13:37
The only way to know if you can get any further in direct mode is to try. There is a slight possibility it could help, but the information given is not promising. With just the ATA passthrough mode, what are the return error and status register values? What are those values when trying to read a sector, and what are they when trying to get SMART?
http://www.hddsuperclone.com
Home of HDDSuperClone
PostPosted: December 24th, 2020, 14:42
SMART data are stored on the platters, so if the SMART attributes cannot be retrieved, then this points to an internal fault.
I don't believe any commercially available tool is yet able to handle this new firmware architecture.
PostPosted: December 24th, 2020, 15:01
The only reason I said there is a slight possibility of the direct mode helping is if the drive goes into device fault after the OS tries to read sectors at startup. When a drive goes into device fault (DF bit of status register set), it will respond to all commands with an abort. The fact that it was stated that it does still identify would likely (but not for sure) indicate it was not in fault, as even the identify command should fail if it was in DF. Like I said, slight possibility, but not very promising. I agree it is likely some other major issue that can't easily be resolved.
PostPosted: December 24th, 2020, 15:13
@maximus Not sure what you are asking so I took pictures, lol.
PostPosted: December 24th, 2020, 15:47
Since you are using the 18.04 version of the live CD, the ATA registers are not returned in passthrough mode so we can't see what they are. I forgot that quit working around 16.04. The interpreted sense code returned is illegal command, which is both weird and probably not a good sign. To see the actual ATA registers would require either using the 32 bit 14.04 version of the live CD, or direct mode.
FYI Since you are using MHDD, I am guessing you have the BIOS in IDE mode. If you power on the drive AFTER you boot the live CD, it won't show to the OS and you can work with it in direct mode in HDDSuperTool.
PostPosted: December 24th, 2020, 16:40
I used HDDSuperTool, and applied power on the drive AFTER it booted the live CD. I selected direct mode and got similar results... If I need to try different options, please let me know and I will get you the results.
PostPosted: December 24th, 2020, 16:49
The drive is reporting that security is locked. This implies that a password has been set.
PostPosted: December 24th, 2020, 16:55
@fzabkar I saw that also, but it has security_enabled=0 below that...so I did not comprehend if it was locked or not?
PostPosted: December 24th, 2020, 16:59
I missed that. :-?
PostPosted: December 24th, 2020, 18:21
The status is an aborted command, but no device fault. Combine that with the security locked but not enabled, and you have a firmware issue, possibly caused by a bad head or heads. If it is not supported by commercial tools such as PC3000, then it would take a DR expert to deal with.
PostPosted: December 24th, 2020, 22:42
I did some more testing with HDDSuperTool.....
2=Red 4TB WD4003FFBX
2=Black 4TB WD4005FZBX
1=Black 6TB WD6003FZBX
1=Red 8TB WD80EFAX
1=White Label 10TB WD100EZAZ
ALL the above have the same symptoms as we have been discussing. The security_locked = 1, security_enabled =0.
NOW:
1=Black 2TB WD2003FZEX
1=Black 4TB WD4005FZBX
These worked with showing smart info, read sectors etc.....What is different? security_lock = 0! Now to figure out how to set the other 7 drives to security_lock=0. Pic attached of working 4TB.
PostPosted: December 24th, 2020, 23:39
Do the working drives make the same clicks as the ones that don't work? If not, then the clicking of the other drives would indicate an internal (heads/media) issue. If the clicking is the same then it would indicate a firmware issue.
PostPosted: December 24th, 2020, 23:42
It is not really a click, more like a chirp... as stalker describes in this thread: https://forum.hddguru.com/viewtopic.php ... 9&start=20
PostPosted: December 24th, 2020, 23:58
Whatever it sounds like, do the non-working drives make any extra noises when powered on? Do they sound different from the working drives?
PostPosted: December 25th, 2020, 6:43
With all these new HGST architecture drives, it the drive cannot read from SA then they report they're password locked.
If you just connect a PCB alone with HDA disconnected it will report as correct model and S/N but as password locked.
PostPosted: December 25th, 2020, 13:43
Thanks, I now recall this thread:
https://forum.hddguru.com/viewtopic.php?f=1&t=40129
Users browsing this forum: Google [Bot] and 86 guests
