 Post subject: One of the things to look for - Broken Seagate Parking Ramps
PostPosted: December 29th, 2020, 2:37
I got bit by this and can tell you I wasted considerable time not looking for it first.
This possibly could have been a 5-10min fix. I can't be sure if this damages the heads at all or knocks them out of alignment.
Model: Seagate ST3000DM001
Date Code: 18106 - 2017-09-11. Site: TK
Symptom: 2 clicks on startup, motor powers down.
Result: Drive reports 4GB usable space, SMART reports 137GB size drive.
Note: With this Barracuda series the 4GB/137GB reporting is what happens when the controller can't read the platters.
It is the controller's default mode.
What's going on? The heads are not traveling past the parking ramp and are being blocked. The controller makes 2 attempts and gives up.
I couldn't see it on mine unless the heads were further retracted off the ramps to get a clean look. You need a head ramp kit to protect the heads and have to remove the top head magnet to slide them off the parking ramp away from the platters.
At some point Seagate went to a cheaper construction of the parking ramp and they can become cracked and interfere with the head guides. It's been going on for years apparently so suspect others have and will have the problem.
Reference this blog post pointing out the issue and difference from 2016 https://www.dq-int.co.uk/blog/seagate-barracuda-ramp-weakness/
 Post subject: Re: One of the things to look for - Broken Seagate Parking R
PostPosted: December 29th, 2020, 7:59
I have seen this on many many Seagate-cases, most common in Time-Capsule drives. Broken ramp will kill heads and surface of at least one platter. Had one case last month were we were lucky and could recover all platters but most cases are only partly recoverable.
PostPosted: December 29th, 2020, 15:48
So the heads do get mangled and cause damage to the platters?
In this case the heads wouldn't even leave the parking ramp so I'm hopeful the platters are ok.
The cracks there look like they were blocking the guides on the ramp but not sure if it's low enough that it kept the heads from slamming together.
A head replacement is suggested when this happens and to not use the original heads after replacing the parking ramp?
PostPosted: December 29th, 2020, 16:03
This is indeed a very common problem with Seagates.
PostPosted: December 29th, 2020, 17:57
+1 seen often on Seagate drives.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: December 30th, 2020, 5:02
What they said, fairly common.
Users browsing this forum: Google [Bot] and 79 guests
