 Post subject: ST1000LM035-1RK172 Zero capacity
PostPosted: January 16th, 2021, 12:31
Hi I have this drive and have ID and with zero capacity, but not access to User area , and it seem sys file 28 is corrupted because I cant read it in anyway, any advice ?
Pewer On
Boot 0x80M
---Mrt UnLock---
LockCode:0xB3977E5A
LockKey:
Rst 0x80MSrv DETCR init 0x0000
EDAC Value = 0000F01800000000
DOS:0 Scan Unit
Send Status: COMRESET seen
CSpd= 6Gbps
DSC
CTRL-X
ATA  40 Cmds
Ts(ms)     dT(ms)   Op Cnt  LBA
         0 99999999 00 0000 000000000000
         0        0 00 0000 000000000000
RW  48 Cmds
Ts(ms)     dT(ms)   xT(ms)  Type Option Mode  St EC       Info
         0 99999999        0 00  000000 000000 0 00000000 SEEK RD USR LBA
         0        0        0 00  000000 000000 0 00000000 SEEK RD USR LBA
      4675     4675        0 2F  000000 000000 1 00000080 SPN_UP NORMAL
      4720       45       10 34  000000 000000 1 00000080 TCC 0
      4730       10        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 000000000001 L 000000000005 BO 000000 BES 028D8E4.028E2E3.028D8E4
      4738        8        4 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000000960E L 000000000001 BO 000000 BES 01EB000.01EBFFF.01EB000
      4742        4       10 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000000960E L 000000000001 BO 000000 BES 01EB000.01EB1FF.01EB000
      4754       12        3 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000073D2 L 000000000002 BO 000000 BES 0225E00.02261FF.0225E00
      4757        3       11 02  811201 000000 1 00000080 XFR RD SYS LBA B 0000000073D6 L 000000000001 BO 000000 BES 0061928.0061B27.0061928
      4773       16       12 02  011201 000000 1 00000080 XFR RD SYS LBA B 000000005781 L 000000000002 BO 000000 BES 042D640.042DA3F.042D640
      4786       13        4 02  011201 000000 1 00000080 XFR RD SYS LBA B 000000004E0D L 000000000001 BO 000000 BES 01A6714.01A6913.01A6714
      4791        5       12 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000053EB L 000000000015 BO 000000 BES 0434840.043723F.0434840
      4807       16       11 02  011201 000000 1 00000080 XFR RD SYS LBA B 000000009603 L 000000000001 BO 000000 BES 01EFE00.01EFFFF.01EFE00
      4818       11       45 02  011201 000000 1 00000080 XFR RD SYS LBA B 000000005D33 L 000000000220 BO 000000 BES 01A6B20.01EAB1F.01A6B20
      4865       47        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000095FF L 000000000004 BO 000000 BES 042D640.062D63B.042D640
      4888       23       11 02  011201 000000 1 00000080 XFR RD SYS LBA B 000000008215 L 000000000001 BO 000000 BES 00F643A.00F6639.00F643A
      4900       12        2 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000000823B L 000000000002 BO 000000 BES 00F663A.00F6A39.00F663A
      4902        2        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 000000008215 L 000000000001 BO 000000 BES 00F643A.00F6639.00F643A
      4911        9        6 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000000A501 L 000000000002 BO 000000 BES 0250E00.02511FF.0250E00
      4917        6      352 02  011201 000000 2 44090082 XFR RD SYS LBA B 000000005783 L 0000000000ED BO 000000 BES 02A0C40.02BE63F.02A0C40
      5277      360     2743 02  011201 000000 2 44090082 XFR RD SYS LBA B 000000005783 L 000000000001 BO 000000 BES 02A0C40.02BE63F.02A0C40
      8029     2752      352 02  011201 000000 2 44090082 XFR RD SYS LBA B 0000000122A3 L 0000000000ED BO 000000 BES 02A0C40.02BE63F.02A0C40
      8389      360     2732 02  011201 000000 2 44090082 XFR RD SYS LBA B 0000000122A3 L 000000000001 BO 000000 BES 02A0C40.02BE63F.02A0C40
     11173     2784       75 02  011201 000000 1 00000080 XFR RD SYS LBA B 000000007CCF L 000000000400 BO 000000 BES 00F86AD.01786AC.00F86AD
     11264       91       19 1B  011201 000000 1 00000080 DEBUG_CAPTURE
     11297       33        3 02  028201 000000 1 00000080 XFR WR SYS LBA B 000000009D81 L 000000000001 BO 000000 BES 00F74AD.00F76AC.00F74AD
     11300        3       13 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000000A90C L 000000000050 BO 000000 BES 0227C00.0231BFF.0227C00
     11315       15       12 02  028201 000000 1 00000080 XFR WR SYS LBA B 000000007193 L 000000000001 BO 000000 BES 00F82AD.00F84AC.00F82AD
     11327       12        7 02  011201 000000 1 00000080 XFR RD SYS LBA B 000000019640 L 000000000001 BO 000000 BES 0254800.02549FF.0254800
     11334        7       13 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000000AE5F L 000000000041 BO 000000 BES 0264A00.026CBFF.0264A00
 Post subject: Re: ST1000LM035-1RK172 Zero capacity
PostPosted: January 21st, 2021, 14:30
PM sent.
PostPosted: January 22nd, 2021, 7:59
I guess you already tried regen translator without backup of 28 or 35 since you have xx82 errors :?
PostPosted: January 23rd, 2021, 17:41
No, I did not, And i have orig 35, but my problem is I cant get 28.
PostPosted: January 24th, 2021, 5:40
Are both copies of 28 totally unreadable?
I don't know about MRT, but in PC3k there's an option to read by single sectors ignoring errors. So sometimes it's possible to patch together one good copy from the two.
PostPosted: January 24th, 2021, 6:39
I dont think MRT have this option, but I should ask their support .
PostPosted: March 3rd, 2021, 12:43
Guys Im still have this issue, any help ?
PostPosted: March 3rd, 2021, 13:09
If you cannot read sys28 with MRT then we cannot help magic it back.
You have a much better chance with PC3K as it can read by single sector and ignore the bad areas.
PostPosted: March 3rd, 2021, 13:42
So if even by PC3K cant read sys 28 there is no chance to get Data ?
PostPosted: March 3rd, 2021, 13:56
Check your PM
PostPosted: March 3rd, 2021, 14:28
it can be solved even with MRT :idea:
Data Recovery Pakistan
PostPosted: March 4th, 2021, 3:55
How exactly?
PostPosted: March 4th, 2021, 7:07
you have to read SA via ABA option in MRT with ignore read error option.
with this you will get 28 sysfile with bad sector, which can be patched and write back .
PostPosted: March 6th, 2021, 13:29
You mean ABA mode automatically ignore error, or I have to change something in MRT? because I already Using ABA and gets error.
PostPosted: March 8th, 2021, 12:38
I have orig sys 35 , do you think if i use m0,6,3 maybe it can lead to read sys 28 ? and then restore orig sys 35?
Users browsing this forum: Google [Bot] and 239 guests
