 Post subject: Hitachi HDS724040KLAT80: PCB swap
PostPosted: February 25th, 2021, 21:10
I'm plannig to swap the PCBs from a working Hitachi 400 GB IDE to a dead patient which is the same model (after swapping the ROM-Chips). The P/N is 0A30228 on both, but the PCBs are not exactly the same (see attached pictures). The MCU is slightly different (Patient: SAB-M3054C21 vs. Donor: SAB-M3054C21-G). The sticker shows 0A30269 BA1148_... (Donor) vs. 0A30269 BA1148A (Patient).
There is an offer at eBay for the same PCB of the patient, but from a drive with damaged platters/heads.
Which PCB is the better choice.
There are two EEPROMs on the PCB. Is the 8pin IC left to the Memorychip the one to be transferred?
File comment: Donor PCB
File comment: Patient PCB
 Post subject: Re: Hitachi HDS724040KLAT80: PCB swap
PostPosted: February 25th, 2021, 22:22
At a minimum you need to transfer the "NVRAM" at U5 (S93C76 / RL76). If the firmware doesn't match, then you will also need to transfer the "ROM" at U7 (25FV051T / SST45LF010). It would be safest to transfer both at the same time.
What is wrong with your drive?
PostPosted: February 25th, 2021, 22:41
The HDD is not spinning. But this happend almost 10 eyears ago and I made a bad mistake (https://forum.hddguru.com/viewtopic.php?f=1&t=19331). Now I have a working drive as possible donor and can purchase an almost identical PCB, but from a damaged HDD. I don't know what's the better option.
PostPosted: February 27th, 2021, 6:00
Any suggestions if it's better to use the slightly different PCB from the working drive or the very similar form the damaged drive?
PostPosted: February 27th, 2021, 17:51
it depends on how very similar it is.
PostPosted: February 27th, 2021, 21:23
Good, that you asked.
Attached is the posted picture of it. I think it matches the PCB of the patient very well.
But I was surprised to read very different P/N and MLC numbers in the description:
Offer:
S/N: RAH6L64C
P/N: 13G0521
MLC: BA1222
Made in: Thailand
PCB Revision: B 0A30261 01
PCB Sticker: 0A30269 BA1148A
PCB Main Chip: 0A29004 SAB-M3054-G21
Patient:
S/N: RAGVJYEC
P/N: 0A30228
MLC: BA1246
Made in: Thailand
PCB Revision: F 0A30261 01
Possible Donor:
S/N: RAGEKMWC
P/N: 030228
MLC: BA1246
Made in: Thailand
(A better arrangement is attached as a PDF-table)
The PCB Revision is described as B 0A30261 01, but the picture shows F 0A30261 01, so maybe the description of the P/N and MLC are also wrong, or the picture shows a different PCB. I have to contact the seller.
Is it possible, that the same PCB is mounted on different HDD revisions? And does it matter for swapping the PCBs?
HDS724040KLAT80 PCBs.pdf [164.38 KiB]
Downloaded 504 times
PCB Controller Hitachi HDS724040KLAT80 _ 13G0521 _ BA1222 _ B 0A30261 01.jpg
PCB Controller Hitachi HDS724040KLAT80 _ 13G0521 _ BA1222 _ B 0A30261 01.jpg [ 458.52 KiB | Viewed 11306 times ]
PostPosted: March 1st, 2021, 2:55
I think the "ROM" at U7 25FV051T of your "patient" PCB is burn. You have to change it with the same from a donor having same number on the second row .
PostPosted: March 1st, 2021, 14:18
From aliexpress ...
PostPosted: March 1st, 2021, 17:16
You think U7 is damaged? Then the same may be true for U7 on the OCB offered at Ebay, because it looks like it is in the same condition. I already ordered this one, because the seller responded to my inquiry and told me the "B" at the PCB Revision was only a typo and the P/N and MLC shouldn't matter if only the PCB is replaced.
If damaged, the firmware on it won't be readable on both PCBs. I'm not sure what firmware it was originally. I found an old HD Tach test, saved as HDS724040KLAT80_KFAOA46A.hdc. "KFAOA46A" is perhaps the firmware number. Or is it written on the sticker at the front side of the drive? It reads "KRFA06".
Anyway, I planned the read the ROMs on a EEPROMer before resoldering on the other PCB. Then I will have certainty.
PostPosted: March 2nd, 2021, 1:50
BE VERY CAREFUL. The LE25FV051T has VCC and GND on pins 2 and 7, not 8 and 4 as most other serial flash memories.
http://pdf.datasheetcatalog.com/datasheets2/15/155977_1.pdf
"KFAOA46A" is the firmware version reported via Identify Device.
I believe the "KRF" in "KRFA06" is a reference to the code name for the family (Kurofune), as is the leading "KF" in the firmware version.
PostPosted: March 2nd, 2021, 9:21
Thank you for this important information.
Users browsing this forum: Google [Bot] and 191 guests
