 Post subject: Stuck with a certain flashes
PostPosted: February 28th, 2020, 7:18
So I have been flashing SAS HDD's using sq_untils I have had a lot of success when the firmware is already available to flash in a .LOD file however I am having an issue with a couple of different drives.
I find I have to flash HDD's after formatting to 512 block size when they have come out of Hitachi servers, so they have the Hitachi firmware on them such as 7FA6 on a ST6000NM0034 drive, I have found firmware from Seagate to flash to E005 or E0G5, when I try this I get this response;
Write buffer cmd: 3b 05 00 00 00 00 19 60 00 00
write buffer: Descriptor format, current; Sense key: Illegal Request
ASC=26, vendor specific qualification ASCQ=99 (hex)
Descriptor type: Field replaceable unit
code=0x3f
Descriptor type: Vendor specific [0x80]
00 00 00 00 00 00 00 00 00 00 00 00 00 00
bad field in Write buffer cdb
Can someone point me to the right post or help me with this error.
Thank you in advance.
 Post subject: Re: Stuck with a certain flashes
PostPosted: November 18th, 2020, 13:06
I'm having this exact same issue. Did you ever find a solution?
PostPosted: November 25th, 2020, 9:37
As of yet I have had no success, the LOD file from Seagate isn't giving a successful flash on these drives.
PostPosted: December 30th, 2020, 21:56
Did either of you find a solution for these 6TB drives?
PostPosted: May 17th, 2021, 6:32
One way is to find an identical model drive with the original firmware, connect JTAG to it and dump the firmware off. Then use that dump to reprogram your drives' firmware over JTAG. Another way is to JTAG dump your existing firmware and reverse engineer enough of it to understand how they capacity limited the drive, and undo the limitation.
PostPosted: May 22nd, 2021, 13:52
I have the same problem, Can the 7FA6 bios be hex edited, to change the vendor code to match the other one link here https://forum.hddguru.com/viewtopic.php?f=13&t=20868 or can this script help https://forum.hddguru.com/viewtopic.php?f=13&t=28252, and I also found this but no info how to flash it in Linux https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=vd3rj. I know how to use a spi flasher can i dump the firmware with that, I found donor boards with right flash chip but cost around 50$ but that kind a lot but i have 2 drive. I have formatted one to 512, with sg_format but it doesnt work, i can right the partition table.
PostPosted: May 26th, 2021, 7:19
redwood, check p.m.
PostPosted: May 28th, 2021, 21:57
I dumped the spi flash from the drive and i also have a drive with ST6000NM0014 same drive but 4k native, can i write over the flash chip then format to 4kn. here a dump of the 520 i wonder is i change serial number and firmware, so i can update firmware with regular update.
csiD
csiD
SEAG
HT813!
yqnI
SEAGATE DKS2F-H6R0SS 7FA6Z4D4F7SF
Copyright (c) 2014 Seagate All rights reserved
Z4D4F7SF0000R63xxxx
naa.5000C50085xxxxxx
<09017FA62014C74300000000C74320142015C74DC74D201500007B01
0508201608312014
ST6000NM0034
P0 {
$(hO
$ Fp
pGB
0#d@
D@@
)F F
@AF8F
)F0F
`pGp
(h,`#
DR1:
=hX5
RF)FXF
G9h@B
`%`e`
%vp
HBh@hRB~#
ShRh[B~$
pG-
#v:
aHAh
DABY
#2F)F F
&<h4
FOF-
'vAFPF
BFYF
0(`SO@
8aMI
aLIJH
JF1F@F
cDc4H
pG.I
` h
DUr%
\F:H]F
!Z)T
AM)P
pGJHA
pG<H
pG9H
hpG7H
F(hh
pGpG8
#)F FT26
pGpGpGpG
HpGJ
-Ex
H*F1F
I*F8F
.D/D
CF:F1F
F1F(F
H2F)F
I2F(F
1F(F
9F0F
pG
"#F)FhF
BF1FHF
`pG-
"1FhF
pG-
$:F1FhF
:FiF
,!AFhF
9FhF
"!FhF
"!F
jF1F(F
"AF,
'D7;
KFAF F
)F`F
"KF=
KF:FAF
")FhF
?H)h
!h2F(h
(h0D(` h0D `
D `(F
Fj (` F
VerifyCtrlFirmwareSignature failed
7AFHF
1FHF
PhF6
0"FO
")F F
)F FU
)F F
`pG-
` h@
` h
!A`[
aAa.K
`pG-H
`pG&H'J
F `
pGp
H cB
*F`
A!a`a
A!a`a
A!a`a
A(Fa
@"C@
`#h#
#`#h#
#`#hC
#`#hC
s#`#hC
#`#h#
C#`#h#
c#`#h#``c
```h
8DjF
[I x
`Y`ZI
#hR
Ih)`@
0`,H
`D`A`
xp`0H
P(`(h
(`8H
&`1H
` h
` h
`*N
b)H0c)Hpc)H
`(h
} h
p ` h
hH0!
BJfJo
bJcJk
YbJcQ
!`XI
Boot 0x
u(h
(`(h
bho
phgho
(a(i
P(a(i
0(a(h
r(h
u(h@
@p(`*H
p `(H
DDYF
QF F
fIfO
i#D\B
vAvI
` k@
c k
b k@
c k
c@
9HAjo
`(I iIB
@h~!BB
EJFIQ
CIDJDKEHEL
`;N6
C&`7J4H5I
8K8L
`*J2I
/J"I/H
*I h*J
'I h'J
1ts1
qAb
ppppppiipppp`ppppppppp
!IH
F~ }"
%YJZI
7L x
.I p
F FN
)I h
(|&K){
\(|Q
!hkF
437826
pz2014-09-0103:36:04
PostPosted: May 28th, 2021, 22:01
the key on the 520 is different then the 4kn but the 4kn is the same as the regular seagate update, 512E and 4kn
P0 {
$(hO
$ Fp
pGB
0#d@
D@@
)F F
@AF8F
)F0F
`pGp
(h,`#
DR1:
=hX5
RF)FXF
G9h@B
`%`e`
%vp
HBh@hRB~#
ShRh[B~$
pG-
#v:
aHAh
DABY
#2F)F F
&<h4
FOF-
'vAFPF
BFYF
0(`SO@
8aMI
aLIJH
JF1F@F
cDc4H
pG.I
` h
DUr%
\F:H]F
!Z)T
AM)P
pGJHA
pG<H
pG9H
hpG7H
F(hh
pGpG8
#)F FT26
pGpGpGpG
HpGJ
-Ex
H*F1F
I*F8F
.D/D
CF:F1F
F1F(F
H2F)F
I2F(F
1F(F
9F0F
pG
"#F)FhF
BF1FHF
`pG-
"1FhF
pG-
$:F1FhF
:FiF
,!AFhF
9FhF
"!FhF
"!F
jF1F(F
"AF,
'D7;
KFAF F
)F`F
"KF=
KF:FAF
")FhF
?H)h
!h2F(h
(h0D(` h0D `
D `(F
Fj (` F
7AFHF
1FHF
PhF6
0"FO
")F F
)F FU
)F F
`pG-
` h@
` h
!A`[
aAa.K
`pG-H
`pG&H'J
F `
pGp
H cB
*F`
A!a`a
A!a`a
A!a`a
A(Fa
@"C@
`#h#
#`#h#
#`#hC
#`#hC
s#`#hC
#`#h#
C#`#h#
c#`#h#``c
```h
8DjF
[I x
`Y`ZI
#hR
Ih)`@
0`,H
`D`A`
xp`0H
P(`(h
(`8H
&`1H
` h
` h
`*N
b)H0c)Hpc)H
`(h
} h
p ` h
hH0!
BJfJo
bJcJk
YbJcQ
!`XI
Boot 0x
u(h
(`(h
bho
phgho
(a(i
P(a(i
0(a(h
r(h
u(h@
@p(`*H
p `(H
DDYF
QF F
fIfO
i#D\B
vAvI
` k@
c k
b k@
c k
c@
9HAjo
`(I iIB
@h~!BB
EJFIQ
CIDJDKEHEL
`;N6
C&`7J4H5I
8K8L
`*J2I
/J"I/H
*I h*J
'I h'J
1ts1
qAb
!IH
F~ }"
%YJZI
7L x
.I p
F FN
)I h
(|&K){
\(|Q
!hkF
437826
PostPosted: May 29th, 2021, 5:33
don't want to be very negative but:
-nope, the serial flash contains critical, unique adaptive data, so completely changing it from a different drive only results in a non-functional unit.
-Moreover, if these are preserved, drive will still fail to init because the main fw is in the SA (on the platters), which obviously won't match the rom version, so won't be started. And ever if it was, you would have the same drive as before.
-Feeding it with a matching fw update could work, but there are version checks for those as well, so it's not very probable either.
-I doubt you would be able to reformat it after the fw update, since such operations require unlocking diag commands.
PostPosted: May 29th, 2021, 10:39
I was thinking that would happen in the firmware up date found the checklist
(P2=%02X) SAP: %s
SAP Subgroups Table of Contents:
SAP length and Raw Hex dump of the entire SAP
All SAP Subgroups
Max Head (maximum head supported by servo)
MR Bias Table (table of MR bias values)
Max MR Bias Table (table of Max MR bias values)
Bias Table (table of Flex Bias values)
Bias Hysteresis Table (table of Bias Hysteresis values)
Table of Contents
Failed update
HjF%
x :_*
#+39JPV^x
CAP:
Invalid
(P1=%02X) Validation Key: %0*X
(P1=%02X) HDA Serial Number:
(P1=%02X) PCBA Serial Number:
(P1=%02X) PCBA Part Number:
(P1=%02X) Head Count: %0*X
(P1=%02X) Node Name Validation Key: %0*X
(P1=%02X) Node Name:
(P1=%02X) Product Family ID: %0*X
(P1=%02X) Product Family Member ID: %0*X
(P1=%02X) PCBA Build Code:
(P1=%02X) ASIC Info:
(P1=%02X) Firmware Key:
(P1=%02X) Firmware Key Checksum: %0*X
(P1=%02X) Date of Manufacture:
(P1=%02X) Destroked Buf Size Index: %0*X
(P1=%02X) Final Mfg Op:
(P1=%02X) Final Mfg Erc:
Undefined
(P1=%02X) System Area Prep State: %0*X
(P1=%02X) SPT Auto Run Delay: %0*X
(P1=%02X) Reserved: %0*X
(P1=%02X) Checksum: %0*X
(P1=%02X) External Model Number:
(P1=%02X) Internal Model Number:
(P1=%02X) IDEMA Capacity: %0*qX
(P1=%02X) Reserved2:
(P1=%02X) Reserved1:
(0`n
Looks like the firmware update the info from the platers around here
UserLBA HBA ParityLBA PBA LogSec PhySec Wdg SuperBlk
InitialPLOLength PLOLength InterSectorGap GapBeforeServo GapAfterServo SequencerPLO1 SequencerPLO
For All Zones All Heads Drive Average Track to Track Seek Time in Servo Bursts = %d (int)
For All Zones All Heads Worst Track to Track Seek Time in Servo Bursts = %d (int)
***Measure Optimum Skew Diag Cylinder Skew Pick = %d (int) = %X (hex)
***Drive Pick for Highest Head Skew for Best Head Switch Write Time = %d (int) = %X (hex)
Drive Pick for Highest MiniZone Skew for Best MiniZone transition Write Time = %d (int) = %X (hex)
***Measure Optimum Skew Diag Average Track to Track Seek Time Pick = %d (int) = %X (hex)
***Measure Optimum Skew Diag Head Skew Pick = %d (int) = %X (hex)
***Measure Optimum Skew Diag MiniZone Skew Pick = %d (int) = %X (hex)
For All Zones All Heads Drive Cylinder Skew Pick = %d (int) = %X (hex)
Drive Pick for Average Track to Track Seek Time in Servo Bursts = %d (int) = %X (hex)
VBAR Adjusted MiniZone Size In Cylinders for Head %2d (int) = %02X (hex)
**** The following information can not be modified by this command ****
***Sequential Track to Track Seek Timing Test Results Summary***
Count DIAGERR RWERR LBA PBA SFI WDG LLL CHS PLP CHS Partition
Unable to save Batch File %X to non-volatile memory.
Batch File %X can still be executed using the Level 6 'B' command.
RAP FW Implementation Key: %02X, Format Rev: %04X, Contents Rev:
LBA span cumm cyl hd sctr zn cyl sctr SFI PBA
Expected DiagError %08X MinCount %04X Actual Count %04X - FAILURE
Expected DiagError %08X MaxCount %04X Actual Count %04X - FAILURE
Addr: 0 1 2 3 4 5 6 7 8 9 A B C D E F
Ix LBA Scnt Dlta Stat | LBA Scnt Atch Strt End Next Prev AC FL
Hd ATISclr PSTESlr DSTESlr ATIRnge PSTERnge DSTERnge OTScnTh NTScnTh PSTEOTScn PSTENTScn DSTEOTScn DSTENTScn StartSU EndSU
Sector Size: %X
Sparing %sabled
Clear Corrupt: %s
Blocks: %X
PI Type: %X
Log Bytes = %X, Log Entry Bytes = %X, Max Entries = %X, Valid Entries = %X
Unrec Err, LBA %012qX, PBA %012qX, Erc %08X, SB %012qX, SB Erc %08X, Trk %X, Hd %X, Sctr %X, Wdg %X, ZnGrp %X, Zn %X
at SrcBlk = %04X Addr = %08X Data = %02X, RefBlk = %04X Addr = %08X Data = %02X
%s Xfer, Start Blk %012qX, Len %012qX, %s %012qX, Erc %08X, Stat %02X
(P2=%X) HeadLoadWithSettlingPeriodicTimerIntervalTableEntry %02X
(P2=%X) HeadLoadWithoutSettlingPeriodicTimerIntervalTableEntry %02X
#3 Low LLR %4X #4 LLR soft sum %4X #5 LLI status %3X
Thresholds: #0 Bits in Error %4X #1 Iterations %4X #2 Erasures %4X
%04X %04X %04X %04X %04X %04X
%04X %04X %04X %04X %04X %04X %04X
Phy Cyl %8.8X Log Hd %1.1X Data Track Percentage %04X Servo Offset Count %04X Data Track Width %04X
Media %s Start, %s, Zone %02X, Start Blk %012qX, Num Sectors %04X
%-2X %02X %-4X %-4X %-4X %3d.%03d %3d.%03d %3d.%03d %012qX %012qX
Sym per media CW %d Sym per user CW %d Intermediate BIE for UC: %d all dec
Warning: Log size exceeds the maximum support by this diagnostic
FrameSensorInfoHeaderBytes %d FrameSensorInfoDataBytes %d SensorAtomicMeasurementIterationDataBytes %d
FrameBytes %d FrameTriggerInfoBytes %d FrameHeadTestResultsBytes %d, FrameSensorInfoBytes %d
Measure Optimum Skew Test Total Elapsed Test Time = %02d:%02d:%02d
Ref voltage %04X Thermistor voltage %04X Thermistor temp in degrees C %04X, %dd
Suspicous LBA tag: Its%4X bits %4X LLR %4X Soft %4X Eras %4X Status %4X SStat %4X LBA tag %4X entry ignored
(P4=%X) ClearanceSettlingMaxActualToPredictedHirpSlopeDelta %e
(P4=%X) SteadyStateExtrapDistanceLowerLimitTgtClrMultiplier %e
(P4=%X) ClearanceSettlingExtrapDistanceLowerLimitTgtClrMultiplier %e
(P4=%X) ClearanceSettlingLastIterationPredictionIntervalLimit %e
PostPosted: May 29th, 2021, 10:57
this is what the drive is Hitachi VSP 5560075-A S2F-H6R0SS 6TB 7.2K 12Gb 3.5 SAS HDD ST6000NM0034, not sure why Hitachi used seagate hdd when they make there own
I was thinking of swapping this in the firmware, then tryng to upgrade with normal seagate update
csiD
csiD
SEAG
HT813!
yqnI
Z4D4F7SF0000R633T1VM
naa.5000C500855C6CC8
0508201608312014
ST6000NM0034
P0 {
$(hO
$ Fp
pGB
0#d@
D@@
)F F
@AF8F
)F0F
`pGp
(h,`#
DR1:
=hX5
RF)FXF
G9h@B
`%`e`
%vp
HBh@hRB~#
ShRh[B~$
pG-
#v:
aHAh
DABY
#2F)F F
&<h4
FOF-
'vAFPF
BFYF
0(`SO@
8aMI
aLIJH
JF1F@F
cDc4H
pG.I
` h
DUr%
\F:H]F
!Z)T
AM)P
pGJHA
pG<H
pG9H
hpG7H
F(hh
pGpG8
#)F FT26
pGpGpGpG
HpGJ
-Ex
H*F1F
I*F8F
.D/D
CF:F1F
F1F(F
H2F)F
I2F(F
1F(F
9F0F
pG
"#F)FhF
BF1FHF
`pG-
"1FhF
pG-
$:F1FhF
:FiF
,!AFhF
9FhF
"!FhF
"!F
jF1F(F
"AF,
'D7;
KFAF F
)F`F
"KF=
KF:FAF
")FhF
?H)h
!h2F(h
(h0D(` h0D `
D `(F
Fj (` F
To
csiD
csiD
SDN1H
yqnI
SEAGATE ST6000NM0014 K0B1Z4D0YFV0
Z4D0YFV00000W5186RM8
naa.5000C5006327C02C
<000C00B12014C74300000000C74320142014C743C743201400007B01
0103201511102014
ST6000NM0014
$(hO
$ Fp
pGB
0#d@
D@@
)F F
@(FAF
1F8F
`pGp
(h,`#
DR1:
z=hX5Y
G9h@B
`%`e`
%vp
HBh@hRB~#
ShRh[B~$
pG-
#v7
_HAh
#"F)F0F
8j8bhF
%0h8
FOF-
'vAFPF
BFYF
ON<`
8aKI
aJIIH
RFAF0F
cDc(h
pG.I
` h
F;HO
!Z)T
AM)P
pGJHA
pG<H
pG9H
hpG7H
xpGp
F(hh
pGpG8
#!F(FT26
pGpGpGpG
HpGJ
+Cx
H*F9F
I*F0F
/D.D
+F2F9F
F1F(F
H2F)F
I2F(F
1F(F
9F0F
pG
"#F)FhF
2FAFHF
`pG-
"1FhF
pG-
F !@
$:F)FhF
:FiF
,!AFhF
9FhF
"!FhF
"1F8
jF!F(F
"AF,
'D7;
KFAF F
aF(F
"KF=
CF2FIF
")FhF
@H!h
)h2F h
h0D `(h0D(`
D `(F
Fj E
the 2nd one matches this in the update and is the same in the hp and dell update
csiD
$(hO
$ Fp
pGB
0#d@
D@@
)F F
@(FAF
1F8F
`pGp
(h,`#
DR1:
z=hX5Y
G9h@B
`%`e`
%vp
HBh@hRB~#
ShRh[B~$
pG-
#v7
_HAh
#"F)F0F
8j8bhF
%0h8
FOF-
'vAFPF
BFYF
ON<`
8aKI
aJIIH
RFAF0F
cDc(h
pG.I
` h
F;HO
!Z)T
AM)P
pGJHA
pG<H
pG9H
hpG7H
xpGp
F(hh
pGpG8
#!F(FT26
pGpGpGpG
HpGJ
ppGP
+Cx
H*F9F
I*F0F
/D.D
+F2F9F
F1F(F
H2F)F
I2F(F
1F(F
9F0F
pG
"#F)FhF
2FAFHF
`pG-
"1FhF
pG-
F !@
$:F)FhF
:FiF
,!AFhF
9FhF
"!FhF
"1F8
jF!F(F
"AF,
'D7;
KFAF F
aF(F
"KF=
CF2FIF
")FhF
@H!h
)h2F h
h0D `(h0D(`
D `(F
Fj E
PostPosted: May 29th, 2021, 13:35
the data you quote here is a part of the bootfw, not even the full container. This goes nowhere, i recommend experimenting with it without posting all the ideas, just post the final conclusion, please.
PostPosted: May 29th, 2021, 17:50
I thought some people had some idea before i brick my drive. here's a like to the full dump. https://github.com/redwoodimage/seagate
and https://github.com/redwoodimage/seagate ... trings.txt
PostPosted: May 30th, 2021, 4:11
Hitachi Virtual Storage Platform use both Seagate and HGST drives. It also use some another drives, such Zeus IOPS etc.
This system use non-standart algorithm for writing to drives. Such SCSI command as WRITE10, WRITE12, WRITE16, etc not used in this drives. It's a "firmware lock". ROM - is a little part of firmware. It need to initial boot. Main code - into HBA. Leave PCB alone. Nobody will restore the damaged ROM.
PostPosted: January 21st, 2022, 5:15
Firendly note: I found ST6000NM0034 includes 2 "types": MLK0034 & NM0034. And 2 rates: 6 Gb/s(Dell MS2D) & 12 Gb/s(Dell MS85).
PostPosted: January 21st, 2022, 13:46
@redwood, just upload your ROM.
PostPosted: January 22nd, 2022, 17:24
I was looking for the answear, similar problem. Thanks
