thanks all of you. Now LED error has gone. Some of the observations are -- 1) After 1~2 minutes drive gives DRD DSC 2) While system file 93 can be read , system file 28 using head 0 cant get read a all using head 1 it can be read partially but is not loaded. 3) There is ROM checksum error -- SEA-3 Yeti Boot ROM 2.0 (12/06/2007) Copyright Seagate 2007
Serial FLASH boot code checksum failure!
Boot Cmds: DS AP <addr> WT <data> RD GO TE BR <divisor> BT WW ? RET > Rst 0x10MBogus ISR CPSR = 0xA00000D7 R14 = 0x00100A80
I think this could be ROM + SA issue.
Full terminal is as following
SðYbÜnFGÄOdåP`ÂæâxÒ&$8iX(Ààøm òPá GÆ@Ë"1ãòÛÜoÐÂAÁ*ASYÄGäÉÔ8c!AtBØý@HiP3iÜ2L=ÄqC2-d-:u&i`FhÛ ÎQxá$õ'>>rUo#\ØHDÁò89 p?vIÀá@%ÛzfôOnQè4ËC! òI2eZKoÁyýc2oÇév&elBä59d[0ð1ýÈ#ÑMmtÈiQÊ%Õ%IsÕQ0)K<Úp IxèÆÀ6ïeÉÙÜ%p5ÑcÚDàô;.Ü ("1HÈgöäÒ5"[öÑç`*õS&?NÆp?:v&fÓu`ÑÈð&kÁiA!üA ÜjáeÕÀ%))lÃ(:2$34ððÑDâIu0È@L"Y7ÔäáQ*mì8m"Àkí 0Á*lpÀ'ßý@B Ã3@ÀÅÀ ÇA$zé_DP0ÀÌH>ÉfáÀ3Ä0bq[ÑôÃÀ1.0Âà@fæ÷,\Ja+ä SB!6SòLYaÃVèpÃ6ántÌ !ÈÞ5A 5?*M@F;aÄ`7Lç"CLÚõ"^èEÐYÑëä@hDH AÃ?HòÈ× h&BK#XßÄD-èÁÉLüÀWúíZsÀÂÚ S ËHa De2áÛ#üvàÊt(S9Ù A!û,CWtÛàx)=)ck.çî%P` JþÍd3<fê<ð3q=ãc7=!ô(9dÂ]bLÀA"m@%#qÙ2Ý#P/WçdPiÂ8Àço9)1Gð"ðgÈT)"E*Í"H,T2jd|Òà0øwÀeï%ÐvNÚ15ÃÌõl Úb6 F3 T> ________________________________________________________________________________________________________________________________________________________________________________________________
F3 T> F3 T> F3 T> F3 T> F3 T> SEA-3 Yeti Boot ROM 2.0 (12/06/2007) Copyright Seagate 2007
Rst 0x10M Rst 0x10M _____________________________________________________________________________________________________________________________________________________________________________________________
Selected family......................... : 3F, Pharaoh Model by ID............................. : <HDD ID NOT READ>
Loading default settings! Use the options dialog to review and save utility settings. Then press OK!
Family default settings loading!
Tech Key... HDD Redynes timeout (10000) Detecting SA Phys Sct Size... Result.................................. : 512 Rd Sys File: vol = A, FID = 32A, Copy = 000... Receiving file FILE_A_32A_0, length = 524288 Parsing container segment....... Flash ROM image Segment: CFW Parsing segment....... CFW End parsing segment... CFW Segment: CAP Parsing segment....... CAP End parsing segment... CAP Segment: RAP Parsing segment....... RAP End parsing segment... RAP Segment: SFW Parsing segment....... SFW End parsing segment... SFW Segment: SHELL Parsing segment....... SHELL End parsing segment... SHELL Segment: SAP Parsing segment....... SAP End parsing segment... SAP Segment: IAP Parsing segment....... IAP End parsing segment... IAP End parsing container segment... Flash ROM image Buff Root FAT searching in RAM......... Ok Searching module table in RAM... ....... Ok Searching DT table(RAM, WR) in RAM...... Ok Searching DT table(RAM, RD) in RAM...... Ok Searching volume 0 file table in RAM.... Rd Sys File: vol = 1, FID = 202, Copy = 000, Offs = 0, Part size = C... Receiving file FILE_1_202_0, length = 12 Rd Sys File: vol = 1, FID = 202, Copy = 000, Offs = 0, Part size = CC... Receiving file FILE_1_202_0, length = 204Ok Searching volume 3 file table in RAM.... Rd Sys File: vol = 1, FID = 203, Copy = 000, Offs = 0, Part size = C... Receiving file FILE_1_203_0, length = 12 Rd Sys File: vol = 1, FID = 203, Copy = 000, Offs = 0, Part size = AF8... Receiving file FILE_1_203_0, length = 2808Ok Searching SMP RAM FID in RAM............ Rd Sys File: vol = 1, FID = 204, Copy = 000, Offs = 0, Part size = C... Receiving file FILE_1_204_0, length = 12 Rd Sys File: vol = 1, FID = 204, Copy = 000, Offs = 0, Part size = 420... Receiving file FILE_1_204_0, length = 1056Ok Searching Non Resident G-List FID in RAM Rd Sys File: vol = 1, FID = 203, Copy = 000, Offs = 0, Part size = C... Receiving file FILE_1_203_0, length = 12 Rd Sys File: vol = 1, FID = 203, Copy = 000, Offs = 0, Part size = AF8... Receiving file FILE_1_203_0, length = 2808Ok Searching CFW OVL FID in RAM............ Rd Sys File: vol = 1, FID = 202, Copy = 000, Offs = 0, Part size = C... Receiving file FILE_1_202_0, length = 12 Rd Sys File: vol = 1, FID = 202, Copy = 000, Offs = 0, Part size = CC... Receiving file FILE_1_202_0, length = 204Ok
Test : Tech Mode unlocking preparation, (patch)
Switching HDD power supply OFF
Switching HDD power supply ON ROM Type: 0x00(STM) ROM Size: 0x80000 Saving ROM to profile folder File : C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Pharaoh\\Data\ROM\ROM_9VM26VGT_3C150682.bin Parsing container segment....... Flash ROM image Warning! Segment header check sum is not zero: 0E46D686 Segment: CFW Parsing segment....... CFW Warning! Segment whole-space check sum is not zero: 00000C1A Warning! Segment used space check sum is not zero: 00000793 End parsing segment... CFW Segment: CAP Parsing segment....... CAP End parsing segment... CAP Segment: RAP Parsing segment....... RAP Warning! Segment whole-space check sum is not zero: 0000034E Warning! Segment used space check sum is not zero: 00004E9F End parsing segment... RAP Segment: SFW Parsing segment....... SFW Warning! Segment whole-space check sum is not zero: 000090CB Warning! Segment used space check sum is not zero: 000003DC End parsing segment... SFW Segment: SHELL Parsing segment....... SHELL End parsing segment... SHELL Segment: SAP Parsing segment....... SAP Warning! Segment whole-space check sum is not zero: 00001D09 Warning! Segment used space check sum is not zero: 0000AFD1 End parsing segment... SAP Segment: IAP Parsing segment....... IAP End parsing segment... IAP End parsing container segment... Flash ROM image No editing objects are found!
| Attachments: |
Screenshot 2021-06-23 201701.png [8.91 KiB]
Not downloaded yet
