 Post subject: Another Maxtor Issue
PostPosted: May 11th, 2005, 15:36
Hi everybody
I'm a new kid on the block so please don't be too harsh please.
I have a Maxtor 4k040h2. Some time ago SMART reported "Reallocated sector count" and all the trouble came - unreadable sectors.PC Refused to boot although SMART was disabled by BIOS and the MAXTOR was a slave. After a format it started working but for a while ... after using a repair program ( i don't remember the name) which "repaired" few sectors SMART reported unreadable sectors ( the repaired ones remained OK)...Now the disk works but ... when trying to close explorer window the closing is delayed for 5 seconds ....
So please recommend some reading or what should I do ?
 Post subject:
PostPosted: May 14th, 2005, 7:49
You have 2 kind of problem IMHO.
1- you need to fix the SMART.
2- You will need to figure out or find soemone that can see what kind of defects your disk has - Logical or Physicals.
Or you can try by yourself if you have nothing better to do, or nothing to loose. ( no ofense, just my opinion )
 Post subject:
PostPosted: May 14th, 2005, 13:39
Miteto,
you can do the following:
Get MHDD form this site :)
Make a boot disk and start it.
Before this Make your drive SM(secondary Master)
Do a SCAN (F4) to see how much the BADs are.
Write zero's to drive (some call it low level format) Be sure to get your important data from the drive. This operation si DATA DESTRUCTIVE
Do Again SCAN and see how much BADs are on the drive. If they are less or nochange.
You can do a SCAN with oprion realocate.
Sometimes when some sectors are marked as predicted BAD and put in G-list is posible SMART error to disaper after scaning drive a few times
 Post subject:
PostPosted: May 14th, 2005, 18:21
Thanks for the replies guys, i'm on it ...
Be here right after the test results ...
 Post subject:
PostPosted: May 15th, 2005, 5:56
Thanks a lot for this tip, so is possible to fix Smart problem using erase in a disk ? or some "zero fill" ?
 Post subject:
PostPosted: May 15th, 2005, 6:18
Sometimes, just sometimes it is possible SMART error to disappear after a few cycles of reading/verifying the drive. I noticed that this most often happens on WD drives and no need of using pc3k ot some other stuff.
 Post subject: RE:I agree
PostPosted: May 15th, 2005, 12:09
Hi $amo,
I'm agree your suggestion because I have this experience before.
But normally I'm move G-list defect to P-list and scan again then the SMART will be.
I'm hope my answer is useful and correct.
Thank you.
back to normal.
 Post subject: SMART repair
PostPosted: May 16th, 2005, 4:37
If the HDD is free from BADs but still reports SMART problems you need to run the respective test - Powermax for Maxtor HDD, DataLifeguard for WD, Drive Ftness Test for IBM and etc.. It will run some SMART tests and if everything is OK with the mechanics it will reset SMART attributes!!!
Users browsing this forum: fabrimote, Google [Bot] and 76 guests
