 Post subject: Seagate HDD not responding to COMRESET
PostPosted: July 11th, 2021, 23:48
Hi all,
my personal laptop HDD (3yrs old) is not getting identified. I keep getting the following on reboot and system won't boot.
Earlier I had few SMART errors on the HDD, but not many (I don't remember the exact number) and I backed up most of the data already but I still do have data of over a month on the disk.
I've worked on storage products (in LSI on Megaraid FW dev., aware of SATA/SAS protocols) a decade ago, so I thought of exploring this further. When I connect diagnostic port, I see that the HDD is receiving COMRESET but is not responding.
my questions:
1. Is it because there are many SMART errors and HDD doesn't want to talk?
2. Is there a way to get back the data by clearing SMART logs? (I tried but I get "diagnostic port locked" message)
3. Is there a way to get back the data without advanced data recovery tools?
Linux logs:
ata1: COMRESET failed (errno=-16)
ata1: reset failed, giving up
HDD into from diagnostic port:
HighPowerMode
XI2Status 0001 Req 0027
Prod Desc: CheopsLiteM.1.0.SATA.Rosewood.Mule.Servo376.Rap30.AP1.4K + SMR Despo DFW
Package Version: RO08B6.HPM1.467804.RSM7
Serial #: WDEX5K58
Changelist: 01325101
Model #: ST1000LM035-1RK172
Servo FW Rev: 6B6A
Heads: 2
PCBA SN: 0000E824H8T9
Default factory config: SD&D
Active config: SD&D
TotalHostWrites 00000000
NumberOfSegWrites 0000
TotalHPCBROs 00000000
TotalBWOs 00000000
MCMTWrites 00000000
Idle1Count 0001
MCSegmentUsed 0EF1
MCNodeUsed 00012C1D
NullNodesUsed 000120F9
Error on diagnostic port
Send Status: COMRESET seen
CSpd= 1.5Gbps
(H) SATA Reset
SSPSaveSettings
SSPRestoreSettings
CSpd= 1.5Gbps
I have attached full logs in the file.
File comment: diagnostic port logs
seagateHDDlogs.txt [9.82 KiB]
Downloaded 545 times
 Post subject: Re: Seagate HDD not responding to COMRESET
PostPosted: July 12th, 2021, 4:46
Can you provide a log for SMART values on this drive?
PostPosted: July 12th, 2021, 5:20
I hope you have checked the attached file. For most of the commands I get "Diagnostic port locked" message. Please let me know if I can provide output from any other command.
Also what is the difference between (P) SATA Reset and (H) SATA Reset?
F3 T>/1
F3 1>N7
Invalid Diag Cmd Parameter
F3 1>N8
HighPowerMode
XI2Status 0001 Req 0027        DERP
  dec       dec                                           error DERP
Hours      Msec        LBA     R  Theta  Z       EC Cmd  type  retry temp count        flag type
     0  00023832   72484448    99   59AA  1 44090081   0  FF     FF   1B     1        00   recovered write
     0  00027484   724868C8    99   B5ED  1  4400102   0  FF     FF   1B     3        00   IOEDC error
     0  00058074   72485C98     3   74DB  1 44090081   0  FF     FF   18     1        00   recovered write
     0  00060373   724868C8    99   B5ED  1  4400102   0  FF     FF   18     1        00   IOEDC error
     0  00062684         B8     4    F40  0       C0  A1  FF     FF   18     2        00   SMART trip
     0  00066343   724868C0    99   585D FC       80   0  FF     FF   1E     1        00   ERC timer exceeded error reported
     0  00069557   724868C8    99   B5ED  1  4400102   0  FF     FF   1E     2        00   IOEDC error
     0  00078766         B8     4    F40  0       C0  A1  FF     FF   20     2        00   SMART trip
     0  00086123   724868C8    99   B5ED  1  4400102   0  FF     FF   18     1        00   IOEDC error
     0  00086806         B8     4    F40  0       C0  A1  FF     FF   18     2        00   SMART trip
     0  00093873   724868C8    99   B5ED  1  4400102   0  FF     FF   18     1        00   IOEDC error
     0  00094798         B8     4    F40  0       C0  A1  FF     FF   18     2        00   SMART trip
F3 1>N6
F3 1>N5
F3 1>N9
PostPosted: July 12th, 2021, 14:02
Never mind.
I figured it out and recovered all the data.
Thank you for your attention.
PostPosted: July 13th, 2021, 14:38
Can you show us what you've done?
Users browsing this forum: No registered users and 263 guests
