 Post subject: WD 2.1.7.1 PBA NOT READING IN DE
PostPosted: November 19th, 2021, 10:57
Using WD 2.1.7.1 810011 unlocked and backed all modules without err.
When I tried to read Sectors in PBA mode using DE. but Even Single sector is not reading but it reads in LBA mode.
Why i m getting err while trying in PBA mode? (I tried PBA reading in old hdd, it reads )
 Post subject: Re: WD 2.1.7.1 PBA NOT READING IN DE
PostPosted: November 20th, 2021, 6:05
Hello ,
Why are you trying to read this hdd in PBA are all sectors zero ?
PostPosted: November 20th, 2021, 9:39
Yes For This case.
But usually it should read in PBA mode ( Tested in WD250....LPCX)
PostPosted: November 21st, 2021, 8:50
gps31 wrote:
Yes For This case.
Well,
have you ever got results in PBA mode in Any WDC with Secondary translator Gone AKA Zero ,In My Case i have never got even with the latest version on PC 3000 ,I wonder what they keep demoing in thier seminars .And mind you the point is to use this technique in SMR Hdds and not CMR Etc ,In CMR Whats the point
PostPosted: November 22nd, 2021, 4:58
For drives with no encryption (ie. some rare SATA drives and some drives manufactured for Russian region where encryption is prohibited), PBA method works with considerably good results, albeit slow.
For drives with encryption it has no effect.
PostPosted: November 28th, 2021, 9:15
Well,
If USB Board can be unlocked and converted to SATA Then ? .
PostPosted: December 16th, 2021, 11:06
gps31 wrote:
Yes For This case.
Outsource.
PM for more details.
Shubh
PostPosted: January 4th, 2022, 3:49
Has Anyone got Solution here ??
Read Fails using MRT Active Utility (PBA Method).
This seems only solution for All sector Zero issue.
Need help. Thanks .
PostPosted: February 9th, 2022, 18:26
This is probably SMR crypted disk. T2 is empty or broken.
"PBA read" and "read through utility" not working for these drives (not decrypt sectors).
You need to repair, rebuild, reconstruct module 190 (189 does not that matter) and read drive through original PCB (with SATA solution) there is only way to decrypt sectors properly.
Maybe MRT or AceLab add new features in future versions to handle this problem.
There are some ideas:
1. If 190 is not empty but broken, can be repaired (tested, working).
2. If 190 is empty can be replaced with a generated artificially covering the entire LBA space, after that reading will be similar to PBA reading. Probably some data can be recovered in RAW but results will not be great. Files in SMR drives are very fragmented. (not tested)
3. In FW area there are some fragments of T2 translator, probably can be gathered and can be used to rebuild module 190. There probably many holes but some data can be recovered, probably result can be better than result from point "2". (not tested).
190 module is similar to simple FAT file system. There is cluster size 4096 and "Fat" table with offsets to each chunk (cluster). Most of file 190 not be used, usually is used in 20-25% only, rest is empty or trashes.
Good luck with your rebuilding!
PostPosted: July 21st, 2022, 13:26
I found same issue also on last 2.1.7.3 version, but my drive is not encrypted.
I used sata pcb that is unlocked.
https://forum.hddguru.com/viewtopic.php ... 13#p298713
My firmware database:
https://mega.nz/folder/O01DkBRI#MxP2J6ZNqXDcrX40I8MoQQ
PostPosted: July 21st, 2022, 22:46
shubhsinghal wrote:
gps31 wrote:
Yes For This case.
Outsource.
Shubh
Well,
Thats so special that you know and other here do not ,What type of magic can you do wth 0x190 totally empty .
Users browsing this forum: No registered users and 43 guests
cron
