Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Dead OCZ Vertex 4
PostPosted: June 2nd, 2022, 17:59
check out old maxtor pcbs (calypso, N40P for example), you will find something interesting. Not very common but exists.
PostPosted: August 2nd, 2023, 1:21
Measure the voltages at the highlighted locations.
Apologies for resurrecting an old thread, however I'm also dealing with a dead OCZ Vertex 4 and was hoping for some assistance in diagnosing the issue.
I have tried to follow along with the diagnostic steps but have been having some difficulty. I have access to DSO, function generator, multimeter and basic LCR (but no ESR meter).
All the capacitors I have inspected do appear to be working - doing a frequency sweep on the DSO between 1Hz and 10kHz at 0.1V I do see the signal amplitude decrease to zero with frequency as expected due to reactance.
I have tried to check resistance between GND and the components suggested by fzabkar. I wasn't able to use the screw hole as they do not appear to be on common ground (?), but using one of the COM lines on the SATA power connector (Pin 4) I had the following readings:
L4 - 1.76kOhm
L3 - 45 Ohm
C68 - Increases and keeps increasing >40kOhms (capacitor charging?)
L2 37 kOhms
L7 Increases up to 40kOhms
L5 - increases up to 50kOhms
L2 14 kOhm
L7 39 kOhm
One thing I noticed which may or may not be relevant is that SATA power connector pins 4, 5, 6, 10, and 12 as well as data connector pins 1, 4, and 7 have 0 resistance between each other, but pin 11 (which as I understand should also be COM) reads 6.3 kOhms between the other COM pins.
PostPosted: August 2nd, 2023, 3:00
Measurements look fine, check the voltages (carefully) next. Are you getting anything from it on the pc at all?
PostPosted: September 25th, 2025, 6:04
File comment: C126 kinda looks like it could be burned?
Hi guys,
Ive got my Vertex 4 dead. with crypto in it. i bought the same working SSD as donor, but im not sure whats the best aproach to fix it.
On my dead SSD no LED comes up, also almost all of capacitors are shorted. only one capacitor (C126) on the back looks darker and kinda burned, but im not sure its the problem. How can i find whats cousing those shorts? if its INDILINX or Hynix or RT9991?
Also would it work if i swap all NANDS with working SSD? or is it better just to swap the those 3 ive mentioned above?
Users browsing this forum: No registered users and 81 guests
