 Post subject: Samsung 860 EVO dead ?
PostPosted: June 29th, 2022, 6:43
Hi All
Just found this forum as was hoping for some help.
After shutdown i cant seem to access my Samsung 860 EVO 1tb ssd...
It can been seen in the Bios but that seems to be about it - its not viewable in disk management. I sent it away to Dataclinic who said that their recovery software wouldnt work on this particular drive.
Currently considering speaking to Ontrack but thought i'd check if there was anything i could do beforehand to possibly gain access to my data ?
Many thanks for any help
podge
 Post subject: Re: Samsung 860 EVO dead ?
PostPosted: June 30th, 2022, 13:13
Those drive have a digital signature, they are not supported by anyone. However you should try to contact a pro and see what they can do, I don't know what tool data medic has, maybe the drive get ready a fraction of seconds and that would be enough to clone it with the right tool. Avoid Ontrack. There's few tech from UK on this forum PCImage, Lardman...
PostPosted: June 30th, 2022, 13:31
Avoid Ontrack. Was it showing the correct capacity in the bios ?
Not knowing what's been previously done to it at dataclinic won't help your chances though. Without main stream software support , it may be possible to image but it's depends on how far things have gone, can't really tell that without the drive in hand.
PostPosted: June 30th, 2022, 13:46
Yes, it was showing 960Gb. Ive no idea what Dataclinic did tbh...
PostPosted: June 30th, 2022, 13:57
i should continue my digging into these it seems...
will check if i can get around the signature.
PostPosted: July 1st, 2022, 4:02
Showing the correct size is a promising sign. You can at least rule out electrical problems and total nand failure.
Options at that stage were to try and brute force the data out which may be very time consuming and the drive might fail completely whist doing it or to look to swap the nand over to another PCB, which is costly as you need a donor drive before you start, isn't guaranteed to work and frankly it's a PITA to do.
If you want confirmation if option 1 is possible which is normally the only financially practical solution for retail clients you're welcome to send it in for a free evaluation.
PostPosted: July 3rd, 2022, 15:48
This is a strange story:
https://forums.tomshardware.com/threads/ssd-possibly-dead-can-only-use-in-read-only-mode.3768534/post-22733127
PostPosted: July 5th, 2022, 7:27
Thanks for that. How would we go about sorting out an evaluation, please?
Users browsing this forum: No registered users and 92 guests
