Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: KSG60ZMV256G TC58NC1000 - rebranded Phison PS3110
PostPosted: June 8th, 2022, 16:19
arvika wrote:
For this model chip-off is possible.
Thank you, that could be another way to explore
PostPosted: June 8th, 2022, 16:26
The only thing that occurs to me is that you could try to find the NAND R/B pin(s) and short one of them to ground during power-on. These pins are open drain, so no damage should result.
Thank you.
You mean 4 GB DDR 3 or the two Toshiba NAND?
https://www.nanya.com/en/Product/4248/NT5CC256M16ER-EK
PostPosted: June 8th, 2022, 16:32
I expect that each NAND would have an R/B pin, perhaps shared, and this pin would be pulled up to 1.8V via a resistor.
I don't know what would happen if you were to "defeat" the SDRAM.
PostPosted: June 8th, 2022, 16:51
OK, I'll investiage each possibility and see what I can do. If I have success recovering data, I'll update this post.
PostPosted: July 13th, 2022, 10:50
Chip-off - no result. Device was encrypted with Bitlocker. Game Over.
PostPosted: July 13th, 2022, 23:11
Well,
Chip off possible in PS3110 , Its interesting to know ,If you can built a file system try UFS pro to decrypt bitlocked partitions ,If the key is somewhere they do this on the fly i just had a case of a Kingston A400 BTW .
PostPosted: November 8th, 2025, 12:05
So have anyone found the ROM Mode of this SSD??
PostPosted: November 9th, 2025, 11:48
The first image shows safe mode.
VEXUS Data Recovery
PostPosted: November 13th, 2025, 6:27
There are methods to recover the BitLocker key, but you must have a computer to connect the drive to and a working drive itself.
Users browsing this forum: No registered users and 114 guests
