 Post subject: Surface Pro Bitlocker
PostPosted: August 11th, 2022, 13:18
Hi Guys,
I got a case of a Surface Pro that failed to boot. Tried to reset it as well as every other advice on the Microsoft website including a recovery USB, it didn't budge. I decided to take out the SSD and connect it to a PC using a PCI card since i don't a the PC3K SSD. The drive shows up as locked on windows as expected. the problem is it only asks for a recovery key. The client provided the Password which i used to enter using the command prompt, it says "Password failed to unlock the volume". Is there any tool that will let me enter the Password or am I outta luck? Any clue will be much appreciated.
 Post subject: Re: Surface Pro Bitlocker
PostPosted: August 11th, 2022, 13:33
You do need the recovery key.
PostPosted: August 11th, 2022, 13:49
Thats what some would call S*** outta luck. Thank you
PostPosted: August 11th, 2022, 16:37
Failed to boot. Why?
If client has no key that's what needs to be solved.
PostPosted: August 12th, 2022, 2:49
My guess would be the OS. Client has the password but not the 48digit recovery key.
PostPosted: August 12th, 2022, 9:25
Tell them to check their one drive account. Most of our surface pro recoveries have been found in there.
https://support.microsoft.com/en-us/win ... 6f5ab347d6
PostPosted: August 12th, 2022, 12:26
We have also found them in MSO accounts as well. You need to check everywhere.
PostPosted: August 14th, 2022, 5:47
The client doesn't have neither a one drive nor any Microsoft account. Wasn't even aware that the bitlocker was active. I get these cases every now and then. My hope was to find a way in using the password.
PostPosted: August 14th, 2022, 20:05
Was he on a active directory?
There is a way for LE to get partial access (knowing what account stored that specific recovery key) but Microsoft needs to provide some Intel.
PostPosted: August 19th, 2022, 8:21
Apologies for the late reply. No he wasn't in any active directory and he can't provide any useful info at this point. I'm running out of ideas here :|
PostPosted: August 19th, 2022, 11:10
Is TPM enabled in BIOS? They key may reside in TPM and the machine pulls they key from there to authenticate.
Users browsing this forum: Google Feedfetcher and 122 guests
