 Post subject:
PostPosted: January 21st, 2004, 12:38
Ok, I have not got data extractor yet so maybe it is better.
Once we have established a working drive we do a disk clone on every job and never extract files from the source drive.
Media Tools - easy to find - US$400, is in my opinion the best I have tested.
Recovers data from "bad sectors" on the fly. Why fix them ?
Read retries up to 32X
Read Timeout & Read Delay
Media Wipe
Analyze, Repair Partitions, BR and more
Editor, Surface test
Often detects drives that bios cannot find and even has correctly found drives that some famous utilities cannot find.
If you are unhappy with your disk cloning software give it a try
Any suggestions for equal or better would be much appreciated.
 Post subject:
PostPosted: January 22nd, 2004, 12:45
hi,
We dont have Data extractor but looking for something same. Can you suggest where to get them
 Post subject:
PostPosted: January 23rd, 2004, 14:27
So what???
Maybe you may tech us??
Достали!!!!. Я тут мимо проходил и решил сказать чего-нибудь безумного.
1.Можете пойти к ремонтникам.
2.Я испытываю естественный скептицизм по поводу чистоты человеческих намерений
3. Дорогу осилит ТОЛЬКО идущий
 Post subject:
PostPosted: January 30th, 2004, 17:53
NAÕ KNOWS IF IT IS A GOOD INFORMATION, BUT HERE I USE A TOOL OF PHYSICAL CLONAGEM OF HDS A LOT AMONG THEM AN I SPECIFY WITH DOLLY NAÕ'S NAME KNOW IF YOU KNOW BUT HE HELPS ME A LOT TO ACCOMPLISH PHYSICAL CLONES!!??? ???
 Post subject:
PostPosted: January 31st, 2004, 5:46
Hello Marcos,
So you have the physical clone equipment - good.
Please tell us about it - where it can bought and how much it costs.
Also some of your experiences with it can be useful here.
regards.
 Post subject:
PostPosted: January 31st, 2004, 6:47
DEAR FRIEND.
THIS PROGRAM AND VERY GOOD REALLY, I DIDN'T GET TO DISCOVER TIES TODAY WHO AND THE OWNER OF HIS/HER PATENT BECAUSE I GOT HIM/IT THROUGH A RECOVERY OF DATA MADE AT THE FACULDADE USP OF SÃO PAULO HERE IN BRAZIL, THE USE HIM AND VERY GOOD IN THE PHYSICAL CLONE,
DEAR FRIEND would LIKE OF IF POSSIBLE he SENDS ME IF SOME LITERATURE ABOUT RECORDING IN SERVANTS, PCBA, BECAUSE HERE IN BRAZIL we HAVE OURSELVES A LOT OF WORK IN THIS AREA BESIDES, I SEEK SOME FORM OF BUYING USED OR it RECONDITIONS PC 3000, AND OR HRT, for ME to HAVE A FASTER WAY to ACCOMPLISH the RECORDING OF SERVANTS, HERE SADLY AND VERY DIFFICULT OF HAVING ACCESS TO THIS EQUIPMENT
AT ONCE THANK YOU VERY MUCH FOR HIS/HER ATTENTION
 Post subject:
PostPosted: March 17th, 2004, 17:02
I think the best disk cloning software is Encase. http://www.guidancesoftware.com . It's used by the FBI.
Also Disk cloning hardware can be found here http://www.logicube.com
 Post subject:
PostPosted: March 17th, 2004, 17:07
best disk cloning software in my opinion is Encase. http://www.guidancesoftware.com
Disk cloning hardware can be found here --- > http://www.logicube.com
 Post subject:
PostPosted: March 26th, 2004, 15:37
Best cloning software is the one made by myself :teeth:
I think everyone here needs information but have none themself, it's a shame but thats life. What you know is worth money, it costs $$ to research yourself, why should I give away my secrets for free?
Maybe need a special forum, for people who know what they are doing and can understand firmware/software and mechanics? Even exchange of good information that can help both parties.
I've had enuff of "Ohhh can't fix my Maxtor, can't do this, don't understand that" Spoon feeding is not an option in this game. If you think your a data rec company then get LEARNING yourself.... Sorry but it gets up my X&^$&$89^(
just my humble opinion..
:cool:
Bye
 Post subject:
PostPosted: March 30th, 2004, 10:04
So what are you here for Guru? to "exchange" information. Surely that means getting information from someone and not LEARNING it yourself.
:D
 Post subject:
PostPosted: March 30th, 2004, 10:58
:D
:D Just want to see how the "Others" try to learn.
Actualy exchange information works <both ways> :me: Unlike yourself. What info have you learned that you have not been told?
Maybe R2D2 can help you, after all he's princess L's "Only Hope" :D :D :D
Bye
 Post subject: best cloning software for HDD
PostPosted: June 6th, 2005, 9:50
well i think media tools professional is very good,
but have a problem its quite slow, i think its beacuse pio mode
its working, its very good when you have many bad sectors,
but i f you dont have many bad sectors try using diskpatch its faster
and using udma66 at least.
there is clonemax ( pc inspector ) didnt tried it so i dont know if its
good , maybee others did??
the fastest and best is hardware cloners but i dont have one myself
Arye S
 Post subject:
PostPosted: June 9th, 2005, 9:00
How do I clone using Encase ??
Encase Enterprise or Encase Forensic ??
Wich one ??
 Post subject:
PostPosted: June 9th, 2005, 9:07
dont know about encase i dont use it currently
use media tolls professional for many badsectors
if you dont have many badsectors use diskpatch
you can PM me further if you need help
Arye S
 Post subject:
PostPosted: June 9th, 2005, 9:53
I don't like MTL, because it hangs on hard drives that have bad sectors. It freezes the program and you have to restart it... :cry:
 Post subject:
PostPosted: June 9th, 2005, 10:07
ok
so what program do you use?
what is the best for bad sectors?
Arye S
 Post subject:
PostPosted: June 9th, 2005, 10:13
Thanks Arye S
I´ll try diskpatch.
 Post subject:
PostPosted: June 10th, 2005, 13:08
Online
I think everybody who has something to do with data recovery has at least to try to make a cloning utility for himself using ATA commands.
This can help to get an idea of how things work on the cable and the board.
And U will have the best cloning utility as well :)
This was amongst the first lessons I took in the beginning.
Now I use many things, but when something is really BAD, I use this 3KB code I have written in assembly.
And I can fine-tune it every time to fit the actual needs.
regards,
 Post subject:
PostPosted: June 14th, 2005, 12:19
I think you're right Pepe... I'll start to work on my own cloning utility because is a very good way to learn while making something useful.
 Post subject:
PostPosted: August 24th, 2005, 1:32
pepe, u say that using AT command to clonning, but how is the command??
Users browsing this forum: No registered users and 250 guests
