 Post subject: Toshiba MQ04ABF100 problem
PostPosted: February 10th, 2023, 17:48
I have got a Toshiba MQ04ABF100 disk . It is getting detected ( although it takes a quite long time) - File Explorer adds the disk as a new driver -
but it stays busy and no files are listed (in File Explorer in Windows.)
Where can be a problem? Is it possible to save the data?
Thank you for suggestions.
 Post subject: Re: Toshiba MQ04ABF100 problem
PostPosted: February 10th, 2023, 18:19
Try cloning it asap before it dies - these drives are no fun to work with once they start acting up, hddsuperclone or ddrescue.
PostPosted: February 11th, 2023, 3:26
Thank you for your reply.
Do you think I will be able to clone the disk even in the current state?
And will the clone work in a correct way?
PostPosted: February 11th, 2023, 5:43
You may get lucky besides your only other option is to send it to a lab for recovery. As to whether a clone will work, that entirely depends on how much can be cloned from the drive - the hardware is obviously failing how much you can get before it causes the firmware to fail is anyone's guess without professional tools.
PostPosted: February 11th, 2023, 13:35
Is this model supported by PC3K or MRT?
PostPosted: February 11th, 2023, 17:28
Is it a software problem or a hardware problem? How can I find that?
The customer did not use PC3K nor MRT
PostPosted: February 12th, 2023, 10:21
Not properly IIRC still the same issues as discussed before and I don't think that's changed with the last update.
IMO it's hardware displaying as logical and will result in firmware. End users aren't expect to have or use PC3K or MRT.
PostPosted: February 14th, 2023, 5:56
In fact it is not.
Yeah, it IDs and there is a family choice for them, but except from the basic stuff, the only useful thing you can do is Techno Off. And sending VSCs through the ATA Commander, of course.
I believe it will be supported much better in the following versions.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 47 guests
