 Post subject: SSD Kingston 480Gb SM2258XT Can't create virtual translator
PostPosted: March 21st, 2023, 11:12
Hello guys, good day.
I'm looking for improvement on my SSD knowledge. I'm here with one that is not a customer case, I'm only studying.
I have a MRT with SSD function.
This SSD recognizes as 14.92Gb when JP1 is short.
This is what I get in MRT:
Selected family : ............................: Silicon Power A55
Master Controller model : ....................: SM2258XT
Chip id : ....................................: 0xAD5E2933A0
Vendor : .....................................: Hynix
SSD state:
Wether it is in a ready state : ..............: Yes
Firmware working mode : ......................: ROM
SSD error code : .............................: 0x00(No error)
Whether SSD is locked : .....................: No
Whether in safe mode : .......................: Yes
Whether access user area : ...................: No
Whether access SA : .........................: No
Load loader...
Read Loader : ................................: success
Loader name : ................................: MPISP_L06_B0KB_S0104D
Write to Loader : ............................: success
Execute Loader code : ........................: success
SSD state:
Firmware working mode : ......................: LDR
Whether in safe mode : .......................: No
Whether access SA : .........................: Yes
Load loader : ................................: success
Basic SSD information:
Read chip information : ......................: success
Flash type : .................................: 3d-96L TLC 16k
Chip capacity : ..............................: 4096 Mb
channel number : .............................: 1
Chip number per channel : ....................: 4
Chip layers : ................................: 2
Number of logical units : ....................: 1
Number of chip storage blocks : ..............: 0x1000
Number of pages per storage block : ..........: 0x80
Page size : ..................................: 0x2000
Maximum retry level : ........................: 0x0
Load relocation block table : ................: Fail
Load CP list......
Load CP list... : ............................: success
Read password information...
Read password information : ..................: Fail
Create Virtual Translator...
Create Virtual Translator : ..................: Fail
---End---
I've tried 3 Loaders that MRT offers to this controller, same results on each. Had others with this controller that I've managed to recover using the same tool, don't know why this one isn't working.
Thank you for any help.
 Post subject: Re: SSD Kingston 480Gb SM2258XT Can't create virtual transla
PostPosted: March 21st, 2023, 12:16
DIY recovery from busy SM2258XT SSD:
http://www.hddoracle.com/viewtopic.php?f=106&t=3238
PostPosted: March 21st, 2023, 16:37
fzabkar, wow, thank you so much for this compilation. I've found this EazyTools some time ago, completely forgot about that.
Now I believe it will be possible. Thank you.
PostPosted: April 26th, 2023, 17:57
fzabkar, Do you have any idea of what MPtool I need to use on this one?
Model: SM2258AB-20-00204000
Fw : 20141211
Size : 0 MB [0.0 GB]
Controller : SM2258AA in ROM Mode
Bank00: 0xad,0x5e,0x29,0x33,0x0,0xa0,0x0,0x0 - Hynix 3dv5-96L TLC 16k 1024Gb/CE 512Gb/die
Bank01: 0xad,0x5e,0x29,0x33,0x0,0xa0,0x0,0x0 - Hynix 3dv5-96L TLC 16k 1024Gb/CE 512Gb/die
Bank02: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank03: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank04: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank05: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank06: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank07: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank08: 0xad,0x5e,0x29,0x33,0x0,0xa0,0x0,0x0 - Hynix 3dv5-96L TLC 16k 1024Gb/CE 512Gb/die
Bank09: 0xad,0x5e,0x29,0x33,0x0,0xa0,0x0,0x0 - Hynix 3dv5-96L TLC 16k 1024Gb/CE 512Gb/die
Don't know if this SM2258AA is supported by EasyTools at all. I did solve the previous case, but now I'm struggling with this one (kingston 480Gb Sata SSD too)
