 Post subject: Need f/w for Maxtor Meteor 90845U3 ( DSP)
PostPosted: June 13th, 2005, 17:14
I need firmware - LDR & modules for
HDA: 03A
PCBA: 09A
Unique:28A
Code: MA5404S0
Mail: gsimon@dziti.com
 Post subject: Hi
PostPosted: June 13th, 2005, 20:41
What utility you are using?
PC3000 can be support?
Thank you.
 Post subject: Re: Hi
PostPosted: June 14th, 2005, 2:50
David Sam wrote:
.....PC3000 can be support?
of course.....
DSP utility......
 Post subject:
PostPosted: June 14th, 2005, 3:53
Are you sure?
U can't access Athena disks using Proxima, or Rigel alias.
So you can't access Maxtor "Quasar, Vega, Mil 3, Norhstar....) using Proxima or some other alias because Reading & writing SA will generate errors. Or at least you can't read some modules...
Correct me if I'm wrong
Samuil Karakashev
 Post subject:
PostPosted: June 14th, 2005, 4:32
I was able to start selfscan on a Northstar drive using Proxima alias. Reading modules, however, was incomplete... In such a case it is not possible to make a loader, I think...
 Post subject: ...........
PostPosted: June 14th, 2005, 5:45
On _Sluzebka , there were a lot of f/w
for
Maxtor Millenium
Maxtor Vega
etc.....
it seems that all of that is ok!!!
I am asking how that is made?
It seems on standard way.....
 Post subject: Re: ...........
PostPosted: June 14th, 2005, 22:19
for
Maxtor Millenium
Maxtor Vega
etc.....
Are you sure?
I'm think PC3000 utility of others software utility?
If using PC3000 utility, sure SA will come error.
Users browsing this forum: Bing [Bot], Google [Bot] and 134 guests
