 Post subject: is there any way to recover the data on wd 2060 701640 001
PostPosted: June 23rd, 2023, 6:37
i have wd 500 av with pcb number 2060-701640-001 rev a but there is no rom on u12.
today when i turn on the computer, the hdd isnot detected on bios. then i force shutdown the computer and open the case. when i try to turn on again, on hdd there is white smoke, so i immediately unplug the cable. i think there is short on pcb.
this is the picture.
i didnot see the rom on u12. is there any hope to recover the data ?
 Post subject: Re: is there any way to recover the data on wd 2060 701640 0
PostPosted: June 23rd, 2023, 7:46
probably the PC's psu got damaged and the drive experienced overvoltage on the 5V line. This is the worse thing that could have happenedt coz the preamp inside the HDA also receives this voltage, so it is likely to be burnt as well and it implies that the MHA probably needs to be replaced without powering up the drive with a replacement PCB. The replacement PCB on the other hand must have the same fw as the patient, or the fw must be matched by other means.
That said, this is likely not a DIY candidate.
PostPosted: June 23rd, 2023, 7:47
That said, this one is likely not a DIY candidate.
PostPosted: June 23rd, 2023, 8:26
iam sorry i dont understand, what is hda, mha ? is preamp the burned one?
how to know the fw ?
it is pcb need replacement from same series, same type ?
PostPosted: June 23rd, 2023, 8:42
HDA= Head and Disk Assembly
MHA (HSA)= Magnetic Head Assembly
preamp is located inside the HDA on the MHA. Read more about these here:
https://hddscan.com/doc/HDD_from_inside.html
I don't recommend messing around with blind pcb swapping if the data is important. Contact a pro in your area who knows what these components are.
PostPosted: June 23rd, 2023, 8:51
www.guruhdd.com
Sutiono should be able to sort it out for you.
PostPosted: June 23rd, 2023, 15:06
PEPE is trying to scare you :D
Hi Pepe!
I wont say the heads are dead unless they are in reality.
PostPosted: June 23rd, 2023, 16:23
@konco1, if you have a multimeter, we can check the resistances of the preamp's supply rails. That will tell you if a PCB swap will work, otherwise you will be wasting your money and time.
Hopefully, this is not what happened to your drive:
https://www.hddoracle.com/viewtopic.php?p=22173#p22173
PostPosted: June 23rd, 2023, 17:03
@sin: i said 'likely' and 'probably'. But apart from the MHA replacement,there are fairly enough issues with this thing to say it is not a candidate for DIY. Ok, what if preamp is ok? replacement pcb still needs compatible fw to be written to MCU as no U12 is present. So in the end he will need pro help anyway...
PostPosted: June 23rd, 2023, 17:47
I have helped an end user recover their data in this situation. That's why I wrote my ROM regeneration tool.
PostPosted: June 24th, 2023, 3:43
Hi Fzabkar. Yes likewise.
@pepe, i am just joking and poking with you my friend. :D
in any case,
What is > What if
Pro consultation should be the way if data is important. Rest DIY is way to go and try out.
Cheers
Users browsing this forum: fabrimote, Google [Bot] and 78 guests
