 Post subject: Samsung 840 EVO 120 GB
PostPosted: September 30th, 2023, 7:07
Hi all
i have a problem with my Samsung 840 EVO 120 GB MZ-7TD120. The drive is not detected by Windows. In BIOS i see this drive but only 1 Gigabyte capacity. I did a basic inspection of the electronics.
and I saw it
Is it possible that this is my problem?
 Post subject: Re: Samsung 840 EVO 120 GB
PostPosted: September 30th, 2023, 7:26
A low capacity like that would indicate a communication issue with the nand or firmware problems.
Check the resistance to ground of the pmic outputs and then check the voltage at the inductors, they don't look to be in the best state but I'd be surprised if they're causing an issue.
PostPosted: October 3rd, 2023, 12:52
ok what about 7 THT hole on this PCB ?
Is it possible that it's JTAG?
can u help me find pinout ?
on this forum im found
http://www2.futureware.at/~philipp/ssd/ ... Manual.pdf
niestety link prowadzący do pinout nie zyje
PostPosted: October 3rd, 2023, 17:08
I took measurements, it looks like this
during measurements, they all tend to zero
PostPosted: October 4th, 2023, 8:57
The voltages appear to be ok which would confirm a firmware/nand issue. I can't help with the jtag I'm afraid, this one could be hooked up to pc3000 to recover the data if that's what you need.
PostPosted: October 4th, 2023, 15:23
Please run my SSD-Diagnostic tool which was made for the EVO840: https://github.com/thesourcerer8/ssddiag
PostPosted: October 6th, 2023, 3:32
ok im order altera USB Blaster or waiting for it
PC-3000 is out of my range
I'm thinking about MRT Ultra with SSD package
I have a question for people with more experience, does MRT deal with this type of problems?
PostPosted: October 26th, 2023, 7:13
ok im recive my altera USB
now im doing measurments on passible JTAG pins
can enyoune help me find jtag pinout ?
it is passible is the same as this ? (from https://www2.futureware.at/~philipp/ssd ... Manual.pdf)
PostPosted: October 27th, 2023, 2:23
Samsung has reused the same pinout on several different models over time. It looks very much like being the same, yes, so I think you can try it.
PostPosted: October 27th, 2023, 6:16
@sourcerer
i have a problem with your script
when i running it
Restarting OpenOCD ...
Connecting to OpenOCD:
Can't call method "send" on an undefined value at ssddiag.pl line 27.
Perl version: 5.36.0-7
PostPosted: October 27th, 2023, 16:46
That looks like the openocd service isn't running or not running with the necessary configuration. I have provided a configuration file which might need to be adapted to your reader configuration: https://github.com/thesourcerer8/SSDdia ... /mex1.conf
PostPosted: October 27th, 2023, 18:44
what do you expect from attaching to it through jtag?
why not outsource the thing to somebody with pc3k, and the appropriate experience?
PostPosted: October 28th, 2023, 6:18
On a daily basis, he deals with computer forensics. I'm just starting my adventure with data recovery, the disks are my property, I'm trying to learn something new. I've ordered MRT Ultra for a good start, but unfortunately MRT won't help in this case
PostPosted: November 23rd, 2023, 13:38
friend @michael chiklis wrote that MRT supports S4LN021X01-8030 controllers, is there a chance that MRT will detect this medium in this condition?
PostPosted: November 23rd, 2023, 14:06
If you have it try it - if you don't send it to someone with pc3000 ssd.
Users browsing this forum: No registered users and 115 guests
