 Post subject: Sandisk 32gb 48mb/s Can somebody share the Pinout
PostPosted: November 19th, 2023, 21:50
Hi everyone
So i am having this Sandisk 32gb 48mb/s SD card
I used Type 4 Pinout from Acelabs Solbase
Got the card to ID but i think it did not id correctly
It ID: 45 3e 96 93 (64gb)
Which is a 64gb SD
Can anyone check if i got the correct pinout???
Or can someone provide a pinout for me
Many Thanks!!!
File comment: Pin
370571391_24270356149278203_6609333899079298480_n.jpg [ 5.43 KiB | Viewed 7651 times ]
File comment: SD card
377149007_1992817674444594_6274814513838974446_n.jpg [ 182.59 KiB | Viewed 7651 times ]
File comment: Acelab Layout
386856653_186840151151909_8183832856344753273_n.png [ 400.22 KiB | Viewed 7651 times ]
 Post subject: Re: Sandisk 32gb 48mb/s Can somebody share the Pinout
PostPosted: November 19th, 2023, 21:54
Here is the ID of PC3000 Flash
File comment: ID
PostPosted: November 20th, 2023, 8:18
Start direct reading mode and see what is in the second half of the dump.
PostPosted: November 20th, 2023, 10:37
Do not doubt, the pinout and chip configuration are entirely accurate. Genuine SanDisk USB drives and SD cards may also undergo production methods that reduce capacity, just like refurbished products, although this is rare.
The chip is labeled as 128GB, but the actual capacity is 256GB
http://flash-matrix.com/
Users browsing this forum: jcan and 36 guests
