 Post subject: CORR error
PostPosted: June 28th, 2005, 0:40
Hy , I all people , i have problems with HDS7222540VLAT20 40
its showinng CORR error RED in State register and DRDY and DSC in yellow so this is good, but CORR what does it meaning, when i use universal utility in pc3000, and select controller Test its showing
Completion code: 5
Controlling Microprocessor Error
DOes any one have a idea
Thans for all u help
PostPosted: June 28th, 2005, 0:49
im forgot this is Passport information
GENERAL CONFIGURATION INFORMATION:
ATA device
Not removable controller and/or device
Number of logival cylinders : 11076
Number of logical heads : 11076
Number of logical sectors per logical track : 11076
Model : +D+D+D+D+D+D+D+D+D+D+D+D+D+D+D+D+D+D+D+D
Serial number : +D+D+D+D+D+D+D+D+D+D
Firmware revision : +D+D+D+D
Number of bytes available on READ/WRITE LONG commands: 11076
Max sectors per interrupt on READ/WRITE MULTIPLE commands: 68
CAPABILITIES:
Standby timer vals as spec in standart are supported
IORDY supported
LBA mode supported
DMA mode supported
Total user addressable sectors (LBA mode only) : 725887812 sectors (354437 Mb)
Current block size for R/W Multiple command: 68
Multiword DMA modes supported:
Multiword DMA Mode 2
Multiword DMA Mode 6
Multiword DMA transfer modes active: Multiword DMA Mode 6
Available Ultra DMA/33 modes:
Ultra DMA/33 Mode 2
Current Ultra DMA/33 mode: Ultra DMA/33 Mode 2
Current PIO Mode : 43
Minimum Multiword DMA transfer cycle time : 11076 ns
Recomended Multiword DMA transfer cycle time : 11076 ns
Minimum PIO transfer cycle time without flow control : 11076 ns
Min PIO transfer cycle time with IORDY flow control : 11076 ns
Major version number:
ATA - 2
ATA - 6
ATA - 8
ATA - 9
ATA - 11
ATA - 13
COMMAND SET SUPPORTED :
Removable feature set
PASSWORD SYSTEM NOT ALOWED ON THIS HDD
 Post subject:
PostPosted: June 28th, 2005, 2:17
If you hear normal calibrating sounds, it is posible that some data lines are broken.
Users browsing this forum: Google [Bot] and 86 guests
