 Post subject: Adata US750 SSD Sata very slow
PostPosted: June 4th, 2024, 22:08
i have a US750 SSD to recover it's identified successfully but when it comes to copy data it becomes very slow and the hot and suggestions about that ?
 Post subject: Re: Adata US750 SSD Sata very slow
PostPosted: June 5th, 2024, 4:08
I think you meant Adata SU750.
Did you run it in technology mode? What's your transfer rate?
What controller do you have there?
This model works rather well with Pc3k. Unless you get an unsupported controller.
Here is an example case report.
https://kodit.pl/odzyskiwanie-danych-z- ... mate-su650
PostPosted: June 5th, 2024, 14:17
yes i mean SU750 Adata sorry about mistyped
the controller is RTS5733DMQ
PostPosted: June 6th, 2024, 7:15
What do you mean 'hot', did you simply point your thermal camera again?
What causes the slowness, how are you copying, using what tool?
You give very little to work with.
Users browsing this forum: No registered users and 14 guests
