 Post subject: ST3500320AS SD15
PostPosted: January 27th, 2023, 10:09
I'm looking for SD15 firmware for 2 platter Moose. I found only for 3 a and 4 platters. I need the version flashable with fdl464 (988 KB?)
 Post subject: Re: ST3500320AS SD15
PostPosted: January 28th, 2023, 6:22
SD15 is SD15 no matter the headmap in ROM. What are you up to?
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: January 28th, 2023, 8:18
I think he's searching the official loader from seagate for updating fw from version SD15 to SD1A.
Probably because seagate is not supporting fw updating of these old drives anymore?
If so, search it here:
http://files.hddguru.com/download/Firmw ... s/Seagate/
download file:
MooseDT-SD1A-2D-8-16-32MB.iso
Direct link: http://files.hddguru.com/download/Firmw ... 6-32MB.iso
Create bootable usb key with Rufus (it will erase all your data on the usb key)
https://rufus.ie/
Use UltraISO to extract the boot file from the ISO (is simple, just open the the iso file in UltraISO and click on "Save Boot File" menĂ¹)
https://www.ultraiso.com/
Output file will be in BIF format (1,4 MB)
Now open it in UltraISO and extract the content into a folder inside the bootable key (folder name must be less than 8 characters, call it SD1A)
Turn off your pc and disconnect all your drives from it, keep attached only your Moose drive that needs to be updated.
Turn on the pc and make it boot from usb key in legacy mode.
In the DOS prompt give command:
cd SD1A
then give coomand
AUTOEXEC.BAT
the update process will start, follow instructions...
When finish, power off PC, reattach all your other drives, remove usb key and start your pc.
WARNING:
Before updating fw, backup all your data on a second drive!
FW update doesn't solve issues as bad sectors on surface, it could cause further problems!
My firmware database:
PostPosted: January 28th, 2023, 12:26
This is the decoded .cfs file for Moose SD1A:
http://users.on.net/~fzabkar/MS-SD1A.TXT
;Moose 7200.11 Disty SDD1 branch
;Moose 7200.11 4 head
ST3500320AS MS01??.SDD1.AD????.?D??.C0F? 2DSD1A.LOD MS010C.SDD1.AQ1700.SD1A.C0FF
ST3500320AS MS01??.SDD1.AQ1300.SD1A.C0FF 2DSD1A.LOD MS010C.SDD1.AQ1700.SD1A.C0FF
ST3500320AS MS01??.SDD1.DS????.?D??.C0F? 2DSD1A.LOD MS010C.SDD1.AQ1700.SD1A.C0FF
ST3500320AS MS01??.SDD1.DY????.?D??.C0F? 2DSD1A.LOD MS010C.SDD1.AQ1700.SD1A.C0FF
ST3500620AS MS01??.SDD1.AD????.?D??.C0F? 2DSD1A.LOD MS010C.SDD1.AQ1700.SD1A.C0FF
ST3500620AS MS01??.SDD1.AQ1300.SD1A.C0FF 2DSD1A.LOD MS010C.SDD1.AQ1700.SD1A.C0FF
ST3500620AS MS01??.SDD1.DS????.?D??.C0F? 2DSD1A.LOD MS010C.SDD1.AQ1700.SD1A.C0FF
ST3500620AS MS01??.SDD1.DY????.?D??.C0F? 2DSD1A.LOD MS010C.SDD1.AQ1700.SD1A.C0FF
ST3500820AS MS01??.SDD1.AD????.?D??.C0F? 2DSD1A.LOD MS010C.SDD1.AQ1700.SD1A.C0FF
ST3500820AS MS01??.SDD1.AQ1300.SD1A.C0FF 2DSD1A.LOD MS010C.SDD1.AQ1700.SD1A.C0FF
ST3500820AS MS01??.SDD1.DS????.?D??.C0F? 2DSD1A.LOD MS010C.SDD1.AQ1700.SD1A.C0FF
ST3500820AS MS01??.SDD1.DY????.?D??.C0F? 2DSD1A.LOD MS010C.SDD1.AQ1700.SD1A.C0FF
;Moose 7200.11 6 head
ST3750330AS MS01??.SDD1.AD????.?D??.B??? 3D4DSD1A.LOD MS011B.SDD1.AQ1700.SD1A.B100
ST3750330AS MS01??.SDD1.AQ1300.SD1A.B100 3D4DSD1A.LOD MS011B.SDD1.AQ1700.SD1A.B100
ST3750330AS MS01??.SDD1.DS????.?D??.B??? 3D4DSD1A.LOD MS011B.SDD1.AQ1700.SD1A.B100
ST3750630AS MS01??.SDD1.AD????.?D??.B??? 3D4DSD1A.LOD MS011B.SDD1.AQ1700.SD1A.B100
ST3750630AS MS01??.SDD1.AQ1300.SD1A.B100 3D4DSD1A.LOD MS011B.SDD1.AQ1700.SD1A.B100
ST3750630AS MS01??.SDD1.DS????.?D??.B??? 3D4DSD1A.LOD MS011B.SDD1.AQ1700.SD1A.B100
;Moose 7200.11 8 head
ST31000340AS MS01??.SDD1.AD????.?D??.B??? 3D4DSD1A.LOD MS011B.SDD1.AQ1700.SD1A.B100
ST31000340AS MS01??.SDD1.AQ0???.?D??.B??? 3D4DSD1A.LOD MS011B.SDD1.AQ1700.SD1A.B100
ST31000340AS MS01??.SDD1.AQ1300.SD1A.B100 3D4DSD1A.LOD MS011B.SDD1.AQ1700.SD1A.B100
ST31000340AS MS01??.SDD1.DY????.?D??.B??? 3D4DSD1A.LOD MS011B.SDD1.AQ1700.SD1A.B100
"2DSD1A.LOD" is the .lod file for the 2-disc models.
PostPosted: January 28th, 2023, 13:53
The loader file i've found in the iso is called:
SD1A2D.LOD
is this wrong?
PostPosted: January 28th, 2023, 14:33
SD1A2D.LOD
is this wrong?
That update package is different than the one I downloaded from Seagate's website years ago, so that would account for the difference. Your update doesn't have a .cfs file, so it relies on the user to make correct choices.
Also, Seagate did issue a faulty update which bricked people's drives, and they then quickly withdrew it and replaced it.
PostPosted: January 28th, 2023, 16:09
I've found the iso on seagate official site, it's the same of that has uploaded on guru firmware section:
https://www.seagate.com/support/kb/firm ... -207951en/
Direct link (2 platter Moose):
https://www.seagate.com/staticfiles/sup ... 6-32MB.iso
Probably seagate did a big mistake years ago that has been fix.
PostPosted: January 28th, 2023, 18:27
ISTR that SD15 was affected by the "BSY bug". I can't understand why anyone would want to install it.
PostPosted: January 29th, 2023, 6:06
Probably he updated to SD1A and something went wrong... now he's thinking that can fix it by downgrading back to SD15.
PostPosted: July 29th, 2024, 16:34
It's been a while, but I'll answer, yes, the problem arose after the upgrade to SD1A. I no longer remember for what reason, in any case, I did not have important data on this disk, so it was disposed of shortly after the founding of this topic - a downgrade to SD15, let alone AD14 would not help, I did not have the opportunity at that moment to build a disk terminal myself, and in my country it cost as much as two such ST3500320AS.
Users browsing this forum: No registered users and 46 guests
