 Post subject: WD Charger WD20SDZW-11JJ8S0 0 Capacity
PostPosted: August 1st, 2024, 11:39
I have an unlocked PCB for this drive, I can read all modules except for 02. Drive IDs with 0 capacity and generic model, no serial.
Can someone post module 02 from a similar drive?
Heads all test ok.
 Post subject: Re: WD Charger WD20SDZW-11JJ8S0 0 Capacity
PostPosted: August 1st, 2024, 13:07
Uploaded module 02 from a donor firmware from a similar model drive and now have full sector access. In case anyone has the same issue.
PostPosted: August 1st, 2024, 21:46
What was the problem with this module was it damaged or unreadable on both copies?
Zero Alpha: zeroalpha.com.au
PostPosted: August 3rd, 2024, 18:14
it's content usually gets corrupted for whatever reason, containing some reinitialized data as far as i remember...
