 Post subject: ST1000DM003 1CH162-305 CC47, no F3, no boot
PostPosted: July 29th, 2025, 21:57
ich switch the pcb board from the old hdd with a "new" one. I dlash first the new ROM File on the chip.
Over TTL i cant switch in F3.
I only get this message:
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
TCC:001C
(P) SATA Reset
HDD Data:
Model: ST1000DM003
PN: 1CH162-305
FW: CC47
PCB: 100717520 REV B
Firmware file in the attach
hdd_old_rom.rar [247.49 KiB]
Downloaded 61 times
 Post subject: Re: ST1000DM003 1CH162-305 CC47, no F3, no boot
PostPosted: July 30th, 2025, 2:48
Maybe start from the beginning, what's going on with the drive?
The ROM is locked to RS communication by default, so you can't do anything without unlocking it.
PostPosted: July 30th, 2025, 8:16
The HDD isn't recognized in the BIOS. The motor is spinning and the read head is moving. How can I unlock the firmware?
PostPosted: July 30th, 2025, 8:34
So, as usual, if the hard drive boots, replacing the electronics is pointless.
The ROM can be unlocked using tools like PC3000/MRT/DFL.
PostPosted: July 30th, 2025, 8:55
Ah, sorry you mean the old own. The old own do nothing. I get no messages by powering on.
PostPosted: July 30th, 2025, 11:36
Blocked terminal on 1CH162?.. Interesting, I hear about it for the first time. :)
And where is the message from Grenada - "Terminal is blocked"?
trainmen,
When shorting the Tx-Rx adapter, the characters are printed ?
And I don't remember what the terminal voltage levels are on the Grenada.
Sometimes it helps to wait 10-15 minutes to get to the terminal.
PostPosted: July 30th, 2025, 11:45
SWM, Have you checked the ROM from the attachment?
PostPosted: July 30th, 2025, 11:52
Lukas, The checksums match the calculated ones.
PostPosted: July 30th, 2025, 11:57
SWM, My mistake, you're right. This version isn't locked :D
trainmen, Ah, sorry you mean the old own. The old own do nothing. I get no messages by powering on
The disk itself did not turn on?
PostPosted: July 30th, 2025, 12:00
Trans implies successful loading of 20E(20F).
Missing small change - (H) SATA Reset...
But, perhaps, the host was not connected. :)
PostPosted: July 30th, 2025, 12:05
Or the SATA connection has a fault in something (hostport-cable-deviceport).
PostPosted: July 30th, 2025, 12:08
It looks that way, but that doesn't explain why he can't get to the terminal...
Or maybe he didn't even try :D
What happens if you try to press CTRL+Z?
PostPosted: July 30th, 2025, 12:14
Maybe it's for the best... If it's not the HDD that's faulty...
PostPosted: July 30th, 2025, 16:52
@ Lukas
I understand it right, i need to shorting the rx and tx channel cable? I am locking all right for a shorting point, but i dont find anything.
I wait now 20 minutes but nothing happens.
Yes the disk dont turn on and now output over TTL.
If i press CTRL + Z, nothing happened.
PostPosted: July 30th, 2025, 18:11
does ctrl-z do anything on the donor? It should. On the patient as well. Are you using an adapter capable of 1.8V signaling?
PostPosted: July 31st, 2025, 18:11
Are your sure it is 1,8V and not 3,3V? I use 1,8V and I read i need 3,3V :/
I see only my command in the terminal, but no answer.
I try it with putty, realterm and seagate tools.
PostPosted: July 31st, 2025, 19:39
Okay, i find my problem. My cable was at the wrong Pin :lol:
Users browsing this forum: No registered users and 241 guests
