 Post subject: Warm-up the HDD and test the HDD in extreme conditions???
PostPosted: July 28th, 2005, 11:07
I am a newbie with this, but I am mainly wondering if there is there a specific way or command to do this using MHDD? I am looking to get the hd running in a more extreme condtion to warm it up to a higher temp and then check the reallocated sector count.
Any thoughts on the best way to do this?
John
 Post subject:
PostPosted: July 28th, 2005, 12:09
There is a command in MHDD — CX.
 Post subject:
PostPosted: July 28th, 2005, 17:18
I saw that but was not sure that was what it was used for. Thanks!
In using that command and getting the HD to a temp higher than that manufacturer high temp rating could I see the reallocated sector count rise if left long enough, or would running this command not cause that to happen on the HD. Would I possibly need to be in an OS?
Thanks,
John
I am basically trying to heat up a drive to the point it may cause the drive to have reallocated sectors where some of those sector could get messed up and cause an OS to lose some files(thus not being able to boot properly). I may be way off base on my exspeiment though.
 Post subject:
PostPosted: July 28th, 2005, 17:43
I don't think this will cause reallocated sectors.
I've tried to heat some drives up to 90 degree centigrade, and nothing bad was happened (except some stickers became black) :-)
 Post subject:
PostPosted: July 28th, 2005, 19:02
HA ha
next time just :evil: it. Then it will definitely have bad sectors!! :lol: :lol: :lol:
 Post subject:
PostPosted: July 31st, 2005, 7:56
:lol:
Yes hitting the drive will generate bad sectors , i will advice to
use a pneumatic hammer .... for better results!!! :evil: :evil:
Users browsing this forum: ANYC3, hass and 260 guests
