 Post subject: WD5000LPVT-22G33T0 - BE01 error - Module ID02 not in Dir - n
PostPosted: June 4th, 2026, 15:16
WD5000LPVT-22G33T0 - BE01 error - Module ID02 not in Dir - need LDR file
Hello everyone,
I have a WD Scorpio Blue that stopped being recognized after an improper disconnection from Windows 10 Disk Manager. I have done full diagnostics with WDMarv 4.3.4 Plus and need help to proceed.
Drive details:
Model: WD5000LPVT-22G33T0
PCB: 2060-771852-001 REV P1
Firmware: 02.4CM
Serial: WXF1C5238682
DCM: HHCVJBN (visible on label)
Symptoms:
Windows shows drive as Unknown, Not Initialized, 0 bytes capacity
Boot time increases significantly when drive is connected
Drive makes one spin attempt followed by 2 clicks then stops
WDMarv diagnostics:
Drive Info reads successfully (firmware versions, head count, zone count all normal)
Error: "Error reading drive information, state - BE01"
Error: "Error reading module ID02, state - Module not in Dir"
Restart FW fails
Load Overlay (new drivers) fails - no LDR files present in installation
What I need:
LDR overlay file compatible with PCB 771852 / firmware family 02.4CM to attempt module directory repair via WDMarv.
Data on the drive is important (CR2 photo files). I am not looking to do a full SA restore from a donor - just need to load the overlay to access and repair the module directory.
Any help is greatly appreciated. Thank you.
 Post subject: Re: WD5000LPVT-22G33T0 - BE01 error - Module ID02 not in Dir
PostPosted: June 4th, 2026, 17:00
https://firmware.hddsurgery.com/dl.php?file=45400&filename=WD5000LPVT-22G33T0-01-01A01-WD-WX41A8239415.zip
Users browsing this forum: Google [Bot] and 70 guests
