 Post subject: Dell/Seagate ST1200MM0007 cannot update to ISO6
PostPosted: Yesterday, 10:53
Hello people.
I purchased a couple of these drives for use in my kludge-tastic home server.
They are intended to be connected to an IBM M5110 as controller flashed to be a "generic" Lsi 2308 IT mode card.
One came with firmware version ISO4, the other with ISO5.
After some fighting, and plugging them in to a Dell h200 that I also purchased (still in ir mode), I managed to get them both up to ISO5, but the "SAS_DRIVE_FIRMWARE_2DDG2_LN_ISO6_A.BIN" refuses to run on these drives.
The error it throws is simply "This update Package is not compatible with your system configuration".
Things I have tried:
Connecting them to the 2308 - same error
Connecting them to the h200 - same error
Creating a virtual machine with a spoofed Dell smbios posing as a Dell r730 with the h200 passed through to the vm running almalinux 9.8 - same error
Extracting the ISO6.fwh file and flashing with sg_write_buffer in a whole lot of variations - rejected
Attempting to update with various methods with the Seagate 003.lod - rejected
Some of these were suggested by googles search ai, but I did check sources.
The problem I am having is they seem to reset after a variable amount of time and get dropped from the bus.
The same ai suggested that ISO6 was made to deal with the droppages.
This is my first time dealing with enterprise HDDs,
 Post subject: Re: Dell/Seagate ST1200MM0007 cannot update to ISO6
PostPosted: Yesterday, 12:08
Here are the links so that people who want to help you don't need to search for the updates like I had to:
https://www.dell.com/support/home/en-au/drivers/driversdetails?driverid=vvjhp (IS04)
https://www.dell.com/support/home/en-au/drivers/driversdetails?driverid=pnvwc (IS05)
https://www.dell.com/support/home/en-au/drivers/driversdetails?driverid=2ddg2 (IS06)
PostPosted: Yesterday, 12:25
Dell's header:
00000000  20 20 20 20 44 45 4C 4C 39 49 53 30 36 49 53 30      DELL9IS06IS0
00000010  30 78 02 00 00 00 00 00 00 00 00 00 00 00 00 00  0x..............
00000020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02  ................
00000040  20 20 31 30 30 36 34 31 20 20 20 20 20 20 20 20    100641
00000050  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
00000060  20 20 20 20 53 54 31 32 30 30 4D 4D 30 30 30 37      ST1200MM0007
00000070  20 20 31 30 30 36 38 30 20 20 20 20 20 20 20 20    100680
00000080  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
00000090  20 20 20 20 20 53 54 39 30 30 4D 4D 30 30 30 37       ST900MM0007
The above header needs to be stripped off if you want to use non-Dell methods.
Alternatively, try changing 0x39 to 0x09:
This is the 05 header:
00000000  20 20 20 20 44 45 4C 4C 09 49 53 30 35 49 53 30      DELL.IS05IS0
00000010  30 78 01 00 00 00 00 00 00 00 00 00 00 00 00 00  0x..............
PostPosted: Today, 8:17
My apologies for not posting links to the updates.
I'm not super familiar with hex editing.
The first part (removing the Dell header) looks simple enough, but my unfamiliarity has left me a little confused by the second part
PostPosted: 14 minutes ago
Well, that was unexpectedly easy in the end. Thank you for letting me know the exact border of the Dell header.
Sg_write_buffer --mode=7 --in./ISO6-EDITED.fwh /dev/sg5 worked instantly.
Thank you your help.
Out of curiosity, would there be any advantage to flashing them as a Seagate disk with the 0003 firmware from the Seagate site? (I can't get a direct link I'm afraid, I could upload the firmware file?)
Users browsing this forum: Google [Bot] and 60 guests
