Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
 Post subject: Re: ADATA Premier Pro SP900 shorting everywhere
PostPosted: July 9th, 2026, 19:03
A Vcore voltage of 1V is OK, as I understand it. The supply voltage seems unaffected by the low resistance. I just don't understand why your two Vcore resistance readings differ.
What can a half bad resistor do?? I mean something is definitelly affecting the Vcore resistance at the resistors
PostPosted: Yesterday, 10:14
Measure the resistance between the L2 inductor and your "shorted" capacitors. Is it 0 ohms?
PostPosted: Yesterday, 15:15
They have from 190 to 220 ohms
PostPosted: Yesterday, 15:32
The attachment SHORTING POINTS 200.JPG is no longer available
I have this Strange resistor. It is not shorted to ground. However when measured between the inductor. It beeps and shows 1 ohm on 1 side and 200 on the other
PostPosted: Yesterday, 15:40
Can you take a better picture so we can see what the component you mean and the circuit board / traces around it.
PostPosted: Yesterday, 15:59
Here you go
FRONT
BACK
PostPosted: Yesterday, 17:43
I think that the anomaly can be explained by power sequencing.
I believe that U6 is a dual step-down converter, MP5506, by Monolithic Power. Unfortunately I can't find a datasheet.
Q1 and Q2 are N-channel MOSFETs (DMG6968U). They appear to be switching the two outputs of the buck converter (1.0V and 2.9V) on and off under the control of U6. The reason that you measure different resistances is that you are measuring different sides of the MOSFET switch when it is turned off. When then SSD is powered on, the switches are closed (MOSFETs turned on) and the voltages are the same on both sides (Drain and Source). In fact, please measure the voltage at the VCC_NAND-Switched test point.
It would appear that one of those capacitors is leaky, but not shorted. This does not prevent the Vcore supply from coming up.
In short, I believe the low resistance is a distraction and the actual problem is firmware related.
DMG6968U, Diodes Inc, N-ch MOSFET, marking 2N4, SOT23:
https://www.diodes.com/datasheet/download/DMG6968U.pdf
PostPosted: Yesterday, 18:15
This is U5.
MP2136, Monolithic Power, stepdown converter, 2.5V - 6V Input, 2MHz, 1A, marking 6Q, QFN6:
https://www.farnell.com/datasheets/2914869.pdf
PostPosted: Yesterday, 18:44
   .-----------. L3  ---    GND     ===      ---   GND
   |   on/off  | ___  |             |^| Q2    |
   |           |-UUU--+-------------+|+-------+-------o   VCC_NAND_switched
   |           |    VCC_NAND
   |  MP5506   |
   |           | ___ Vcore
   |           |-UUU--+-------------+|+-------+-------o   Vcore_switched
   |   on/off  | L2   |             |V|       |
   '-----------'     ---         Q1 ===      ---
         |           ---              |      --- 20 ohms
         |   210 ohms |               |       |
         |           GND              |      GND
PostPosted: Today, 9:18
because the light indicators on PC3000 Portable Pro only shows that way when there is a short on the board. If the board is not shorted the light should came in BSY if there is a problem with Firmware of the drive
this only means the sata interface is not configured, which happens when fw fails to load as well. Since in rom mode it works well, it points towards fw corruption. I aslo met this kind of thing in the past...
verifying supply rails is a good idea, but most likely the issue is fw related.
PostPosted: Today, 10:44
Is 20 ohms a normal resistance for this core? My understanding is that Sandforce didn't use ARM cores, so a figure of ~100 ohms may not be a reasonable assumption.
Users browsing this forum: No registered users and 35 guests
