Post new topic Reply to topic  [ 275 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14
 Post subject: Re: HDDSuperClone - A new Linux hard drive cloning/imaging t
PostPosted: July 17th, 2026, 3:46
Adding some interesting new features to OpenSuperClone. The program will soon support serial commands both through the UI and script engine
with any UART adapter. I've added some scripts for Seagate F3 drives (some obviously quite dangerous).
Also in the process of building some companion hardware that combines relays, current monitoriong (and overcurrent protection), and an integrated
serial port. Hardware is proprietary but the software implementation is obviously open source so people will be able to build their own (if they want to
waste as much time on this as I have).
Sometimes I build stuff - https://github.com/ISpillMyDrink
PostPosted: July 17th, 2026, 5:40
But this is something you'll be offering?
PostPosted: July 17th, 2026, 6:12
Yes, I'm working on a little kit consisting of the main power cycling board, an expansion card for M.2 drives (working on native NVMe support in OSC aswell),
and H10/H20 adapter for Optane drives.
PostPosted: July 17th, 2026, 6:30
USB or SATA - SATA current monitoring with decent software alone is something I know would be very useful as an addition to the versions of pc3000 without it. Would be even nicer if it was also usb.
PostPosted: July 17th, 2026, 12:38
If I understand correctly, Deepspar's USB Stabilizer can implement a "soft" reset by interrupting the USB data lines in USB storage devices. Perhaps you might consider adding a differential switch or a USB redriver?
HD3SS3412, Texas Instruments, 4-Channel High-Performance Differential Switch, 3.3V, WQFN-42:
http://www.ti.com/lit/ds/symlink/hd3ss3412.pdf
USB redrivers:
https://www.ti.com/product-category/interface/usb-ics/usb-redrivers-multiplexers/products.html
On the SATA side ...
MAX4952, Maxim, Quad Equalized 1.5/3.0/6.0GT/s SAS/SATA Redriver, 3.3V, TQFN-42:
https://datasheets.maximintegrated.com/ ... AX4952.pdf
PostPosted: July 21st, 2026, 15:24
It's certainly something to think about; I must admit I hadn't thought about just disrupting the data lines
and I don't even know how most USB devices react to that / whether that would actually make much of
a difference for most SATA attached storage.
I'd love some more info on that.
PostPosted: July 24th, 2026, 13:13
"Using a differential switch to control $D+/D-$, followed by a $V_{BUS}$ power switch controlled via a script inside OpenSuperClone, will give you a result very close to how professional DeepSpar devices operate in a Linux environment."
PostPosted: July 26th, 2026, 23:48
Not dealt with SAS drives much. Does OpenSuperClone support SAS drives? Looks like it was available in the Pro ver of HDDsuperClone.
My goal is to image drives from a server RAID
I have a Dell server available, but the drives are not Dell. I am guessing I won't be able to use that to image the drives. I believe servers have compatibility issues with drives not approved for different servers?
If I need to get a PCIe SAS card, Ive seen posts indicating I need a HBA not a RAID card?
PostPosted: August 10th, 2026, 5:54
maximus, can you convert hdd disk from sas model hus724040als640 to sata model hus724040ale604?
PostPosted: August 10th, 2026, 8:40
Ignoring the fact I run lots of off brand drives in my dell server . I grabbed a SAS to SATA adapter a while back from AE, I've used it to image drives in DE so I see no reason why OPSC or HDDSC wouldnt work with it just to image a few drives.
PostPosted: August 11th, 2026, 8:21
Thanks, I have a PCIe SAS card (HBA) and the cables just came in, so I will give it shot.
PostPosted: August 11th, 2026, 19:06
The open source release of HDDSuperClone had all of the pro options unlocked so it should work. Actually I think it only needed the pro options for drives with sector sizes other than 512. I would expect that OpenSuperClone would work the same as long as nothing was removed.
The most direct way to access SAS drives is with the PCIe card, using the Direct SCSI mode, which is needed for odd size sectors. I know with that mode there are speed issues with the odd size sectors, but I can't remember if the slow speed issue affected the normal 512 sector drives or not. If it seems to read slow, know it may be because the OS doesn't deal very well with the odd size sectors, I think it is something to do with internal buffer size. Your mileage will vary, but it should read it and be able to deal with bad sectors, at least as good as possible with the Direct SCSI mode.
http://www.hddsuperclone.com
Home of HDDSuperClone
PostPosted: August 12th, 2026, 3:54
Great Project MAXIMUS i have sent you PM please check and get back to me thanks.
PostPosted: August 17th, 2026, 12:19
Thanks a lot Maximus.
For normal day to day cloning / imaging SATA Drives/ SSD's & NVME SSD's which mode must be used ?
Can you pls. reply.
PostPosted: August 17th, 2026, 12:41
Good work @maximus i have sent you DM please check & reply thanks.
Users browsing this forum: No registered users and 14 guests
