 Post subject: u6 cert problem?
PostPosted: August 2nd, 2005, 0:45
pcb do not supperly power after u6 cert ROM uploade flash ,why?
 Post subject: Re: u6 cert problem?
PostPosted: August 2nd, 2005, 1:07
I think, you upload flash via terminal, and flash was downloaded via terminal too? Via terminal U6 reads flash incorrectly. You need flash, readed via programmator or on the PCB of Fujitsu drive. And after this flash must be prepared for uploading. In your case needs to reprogram flash using programmator.
 Post subject: pcb do not supperly power after u6 cert ROM uploade flash ,w
PostPosted: August 2nd, 2005, 2:06
flash was downloaded via terminal too? yes
how to do reprogram flash using programmator?format?
PostPosted: August 2nd, 2005, 12:18
true terminal or ATA upload?
Why you playing with U6 cert ROMS ;o)
 Post subject:
PostPosted: August 2nd, 2005, 12:37
You must desolder flash chip from PCB..., and program chip in external memory programmer...
http://www.elektroda.pl/rtvforum/viewto ... t=#1470129
Which one is HDD firmware ver. ?
Mikippp
 Post subject: Which one is HDD firmware ver. ?
PostPosted: August 2nd, 2005, 23:16
u6 firmware ver 3.39
I use bios programer or terminal upload .
Users browsing this forum: No registered users and 192 guests
