 Post subject: Iron wolf 4TB Drive - Cimarron Family
PostPosted: August 5th, 2026, 7:09
When i try to patch the rom and write them back i get "Seagate flash boot code" error in terminal, I tried with all the 3 patches but its the same i have attached the rom as well can any one help me patch this rom for me
Drive details:
ST4000NE001
2MA101-500
F/W: EN01
 Post subject: Re: Iron wolf 4TB Drive - Cimarron Family
PostPosted: August 5th, 2026, 10:13
I do not understand the need to mess with the disk firmware. Unless the disk is dysfunctional leave well enough alone.
PostPosted: August 5th, 2026, 18:36
Drive details:
ST4000NE001
2MA101-500
F/W: EN01
I don't see a file. Ensure you start the utility with the family selected. Generic F3 can create this issue.
PostPosted: August 5th, 2026, 21:34
Bold statement with as little information about the reason for messing with the firmware.
PostPosted: August 6th, 2026, 2:26
Not able to get sector access, for the reason i need rom patch to get sys files access
File comment: Have attached the original rom
ROM_WS24SYG3_0C7B1D6A.rar [346.49 KiB]
Downloaded 68 times
PostPosted: August 10th, 2026, 6:34
can you share the full terminal log on power up... it will explain many things...
Data Recovery Pakistan
PostPosted: August 10th, 2026, 9:14
Hi pls find the below terminal log
Terminal log before ROM patch
Boot0x0100MBJ0371EN01
Trans
Rst0x0100MBJ0371EN01
(P)SATAReset
NVCScramSavedHBSize:020A
LD:MD_Alloc:000000F0HB_Alloc:0000DiscRestoreMD_Saved:000000F0HB_Saved:00000000MD_CRC:8679
PP:MD_Alloc:0000F000HB_Alloc:0000DiscRestore
PVTSize:00045458 CompSize:000008BE DeCompSize:00045458MD_Saved:000008BEHB_Saved:00000000MD_CRC:44CC
TW:MD_Alloc:00000400HB_Alloc:002EDiscRestoreMD_Saved:00000160HB_Saved:00000000MD_CRC:0000
GC:MD_Alloc:00005000HB_Alloc:0000DiscRestoreMD_Saved:00004320HB_Saved:00000000MD_CRC:2AE0
DSP029F
2Sync:0 4
No Sector access
Terminal Log after patching ROM
Flash boot code Digital Signature Verification failure!
Flash boot code checksum failure!
SEA3 Boot ROM 2.0 (08/01/2016)
Copyright Seagate 2016
PostPosted: August 11th, 2026, 10:53
Trans
(P)SATAReset
DSP029F
2Sync:0 4
No Sector access
the first log seems fine, NVC is intact,
did you send handshake while checksum failure error in terminal on new drives this is normal... after handshake drive started spinning and unlock..
PostPosted: August 12th, 2026, 3:55
Trans
(P)SATAReset
DSP029F
2Sync:0 4
No Sector access
Hi thank you so much for the support, it worked after translator regeneration got all sector access
Users browsing this forum: Google [Bot] and 226 guests
