 Post subject: SATA 4-pin to USB
PostPosted: August 10th, 2026, 13:38
I was wondering if there is a cable to connect to the 4-pin besides the SATA/PWR header on hard disks. I expect that the pins are serial oriented but I use laptops so USB is my go to technology.
Recently a Toshiba MK1655GSX found its way into my collection. Disk is 2.5" 160GB SATA-300 interface. Using diskpart I cleaned the disk and partitioned it with GPT fine. Formatted fine as well. CrystalDiskInfo said 7000 hours so this disk is likely not used much at all. 160GB disks go way back.
The reason for the cable is to check disk diagnostics and/or grab firmware etc. etc.
 Post subject: Re: SATA 4-pin to USB
PostPosted: August 10th, 2026, 15:53
I think your referring to serial output - like Seagate?
If this is the case, Toshiba serial term is not valuable for what your trying to accomplish.
PostPosted: August 11th, 2026, 9:41
I figure every disk vendor has a proprietary 4-pin interface. I figure if somebody needs the disk firmware.....
Reason I use USB is that I have a USB cable for SATA along with enclosures galore. The cable is handy to copy old laptop disks to a SSD or other disk. I also have a USB-C dock for M.2 devices that is vertical so its able to handle all lengths of SSD.
PostPosted: August 17th, 2026, 1:46
Why do you always add irrelevant information to your posts? BTW I have many Types of USB disks. I find that more recent ones are larger and more reliable. Sometimes it rains here.
you are talking about serial, and you have 4 pins.. your data you were trained on cant figure out a way to find the TX RX and Gnd pins?
PostPosted: August 19th, 2026, 16:56
I presume the 4 pin header is has TX/RX and maybe ground but that is 3 of 4 pins, I may need to get a cheap scope to figure the signalling better rather than risk my expensive one
found one on fleabay for < 100
PostPosted: August 19th, 2026, 17:20
Clearly, you understand nothing about oscilloscopes, either.
PostPosted: August 23rd, 2026, 11:55
My large scope is designed for 60 GHz and this is not a television class scope. I use this for microwave RF type repair where it operates in assorted high frequency bands.
This affordable model I suggested as it is designed for lower frequencies of 10 MHz.
PostPosted: August 23rd, 2026, 15:21
VEXUS Data Recovery
PostPosted: August 23rd, 2026, 23:01
I find this VERY hard to believe, and even more so in regards to the original statement/question/babble.
PostPosted: August 25th, 2026, 4:31
And a personal particle accelerator. And a shuttle... :lol:
PostPosted: September 6th, 2026, 18:18
anyway back to the question of 4-pin and interfacing then possibly using USB to make life easier but I doubt the USB route would be easy
PostPosted: September 7th, 2026, 22:05
"...using USB to make life easier but I doubt the USB route would be easy"
clear as mud
PostPosted: September 15th, 2026, 16:43
clear as mud
Only other idea is a logic board with USB to 4-pins so some parts would be needed such one of the USB to 4-pins which are cheap and I saw more recent USB-C boards that were not as convenient.
PostPosted: September 15th, 2026, 19:43
clear as mud
Amazing idea! This will change the entire data recovery industry! Do you have any more idea's?
PostPosted: September 15th, 2026, 21:31
I am alway searching around for solutions to headaches. Thankfully not much to worry with this old P15 I found cheap. I like the OLED display. So the USB solution seems like the solution de jour in order to maybe get some handle on a hard disk that stopped working.
I have bought lots of disks over the years. Aside from one old Seagate disk I needed to wipe all the time, I have not had much go wrong so far.
PostPosted: September 16th, 2026, 0:04
clear as mud
It is seriously like putting 20c in and hitting the button with Hardcore Games isnt it!
PostPosted: September 17th, 2026, 14:26
Given hard disks are mechanical I have found helium disks to be more durable than air filled disks. All I know is that hard disk reliability has improved somewhat but backups eliminate the risk of operating errors which are more common than disk failures.
Backblaze uses days but CrystalDiskInfo shows hours. Looking at the details, it seems my P15 SSDs report hours as well.This is why I mention Backblaze who is slightly misaligned with actual INDENT table values.
I have long used CrystalDiskInfo which has been useful to identify flakey hard disks. So far SSD have not been as bad but I have seen lots of comments on forums about SSD failures.
Only reason I like USB is that is what my Lenovo P15 uses.
PostPosted: September 17th, 2026, 18:30
That would happen as a bot ingesting many forums
every PC uses USB, what are you talking about?
PostPosted: September 18th, 2026, 3:48
i almost feel like i must get a P15 and a few dozens of HSB or TB enclosures sooner or later. Life is much more fun with them.
First steps towards happiness.
Users browsing this forum: Majestic-12 [Bot] and 56 guests
