 Post subject: mhdd will work i know
PostPosted: August 2nd, 2005, 2:45
Thanks a lot guys,
i know that mhdd will do it. I was just asking that i would be able to do it without stoping the spindle or not.
For your refence i did something like it.
1. I boot the system with mtl.
2. Did the hot swap without stoping the spindle.
3. Re-Scan the disks. MTL shows the data of the disk ( but the serial number was of the previus disk ). So, i think it was successful.
Your thoughts ?
regards
 Post subject: Re: mhdd will work i know
PostPosted: August 2nd, 2005, 5:05
GURUDEV wrote:
Thanks a lot guys,
regards
step 1. - wrong
step 2. - wrong
step 3. - if the drive reads - wrong data.
Read procedure again and stick to it - exactly.
Even then you won't get correct data.
Procedure is not intended to get data recovery.
Procedure is intended to give possible opportunity
to access firmware.
Further step 2 - gives good chance to destroy pcb
and maybe some hda components.
 Post subject:
PostPosted: August 2nd, 2005, 15:09
Hi, Fujimax,
I used HS to access the data itself if the FW was so corrupt it seemed to be impossible to repair.
It is pretty useful if one has a good SW to rebuild the sector structure.
I have written one, not too professional, but it never leaved me in trouble.
 Post subject: Hi Pepe
PostPosted: August 3rd, 2005, 2:21
Hi Pepe,
according to your experience on which hdds will HS work. Someone told me on another forum that it will not on WD disks.
regards
Users browsing this forum: No registered users and 224 guests
