Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: 64GB SATA SanDisk SSD reports 9PB of host writes
PostPosted: September 3rd, 2026, 14:03
I optimized my 1TB Crucial SATA SSD and observed an increase of 64.2MB in the Host Writes count.
    838GiB -- total size of C: volume
    142GiB -- free space in C: volume
    Host writes before optimize -- 0x17b8ed77f
    Host writes after optimize -- 0x17b90c19f
    0x17b90c19f - 0x17b8ed77f = 125472
    (0x17b90c19f - 0x17b8ed77f) x 512 bytes = 64.2 MB
I confirmed that the units for the Host Writes attribute were single sectors by writing a 1.3GB file and comparing the before-and-after counts.
The OS was Windows 10.
PostPosted: September 3rd, 2026, 14:59
And one TRIM command generates at least 1 sector worth of host writes. AFAIK per command max 2 GB can be trimmed. To TRIM his 64 GB drive 32 sectors worth of host writes would be required, if I understand and remember correctly.
PostPosted: September 3rd, 2026, 15:45
The ATA standard defines DATA SET MANAGEMENT (06h) and DATA SET MANAGEMENT XL (07h) commands.
For the former ...
    63:48 RANGE LENGTH field
    47:0 LBA VALUE field
For the latter ...
    127:64 RANGE LENGTH field
    63:48 Reserved
My take on the SMART Host Writes attribute is that it counts ATA WRITE SECTOR(S) commands (30h). If that's the case, then TRIM commands should not affect this counter. If this were not the case, then READ SECTOR(S) commands (20h) would also increment the Host Writes counter.
PostPosted: September 3rd, 2026, 18:46
Read sector does not send 512 bytes of data to the drive, TRIM does. It provides a "map" of LBA ranges to be trimmed, a range list as a data block. I think this is what's going on and why it is counted as host write.
PostPosted: September 4th, 2026, 1:31
Oops, brain fart. I was thinking of SMART READ LOG commands and confused myself. I wonder if IDENTIFY DEVICE increments the host reads counter for the same reason?
PostPosted: September 13th, 2026, 9:27
My idea of thrashing storage is to write enough blocks to fill every available sector, erase and repeat. This is how I test hard disks to be sure the blocks are cleaned up.
Some SD card tools do this to determine if the card is real or counterfeit.
PostPosted: September 13th, 2026, 12:57
Has zero to do with what's being discussed.
PostPosted: September 19th, 2026, 12:13
I recall some time ago a person with a bunch of old SATA SSD wrote to them far above the guaranteed write endurance. Some 3-5x more suggests the endurance ratings are intentionally conservative for minimizing warranty claims. This was not some gimmick with TRIM, it was full SSD writes.
Most SSD I own came with 5 years but the warranty is not much with low cost SSD back before the AI bubble. The low cost Chinese brands come and go but no complaints as the TLC SSD endurance is comparatively good.
Some server SSD that support 1 drive write per day must have lots of spare blocks as that is a rather brutal workload.Consumer class SSD at 2TB can survive Windows 11 a lot better then the 64GB minimum which would likely be trashed in < 2 years. I like 2TB as there is lots of room for software.
Users browsing this forum: No registered users and 80 guests
