Forum rules
 Post subject: Seagate DKS2E-H4R0SS Unlock with Generic Seagate Firmware
PostPosted: June 26th, 2024, 5:13
Need help with Seagate DKS2E-H4R0SS Unlock with Generic Seagate Firmware.
I am willing to compensate financially to anyone who is willing to put in the effort and help me achieve this.
So far I have tried formatting these disks from 520 Bytes to 512 bytes using sg_utils but even after formatting successfully. They fail when we try to write data onto them. I assume its a custom Hitachi storage firmware that has locked the disks to work in Hitachi storage only. A generic firmawre would remove this limitation and i would be able to use the disks again.
i can provide further information if required.
 Post subject: Re: Seagate DKS2E-H4R0SS Unlock with Generic Seagate Firmwar
PostPosted: April 6th, 2026, 11:26
Hi there,
I was just wondering if you ever managed to get your drives working?
I have ten of these drives and I'm struggling.
I have managed to flash the firmware and format to 512 block size, but I'm still having issues formatting to NTFS in Windows Disk Manager.
I have located the original Seagate firmware which can be found here:https://files.hddguru.com/download/Firmware%20updates/Seagate/ConstellationES3-Megalodon-SAS-STD-E007.zip
I updated the firmware using openSeaChest and the drives now show the correct model number (they are no longer listed as DKS2E-H4R0SS)
If you have any advice it would be appreciated
PostPosted: Today, 5:04
Hum, I have processed hundreds of DKS2E-H4R0SS drives. Format to 512 block size with sg_format and then flash with generic Seagate firmware E007 (MD5sum 6a03b216b6c6a7cc98b61e55b709160e) and presuming they passed the sg_format (a significant percentage died at this stage or developed large numbers of reallocated sectors) they work just fine.
If after doing all this you are having problems then the problem is with your setup not the drives.
