 Post subject: TOSHIBA MQ01ABD050 ROM Problem
PostPosted: Yesterday, 15:20
Hi everyone!
I have this Toshiba drive
It came in with not original ROM (The drive does spin and gets to Ready status. However the Serial Number and FW are all wrong from the label)
So i got the patient to gimme the original ROM
However when soldering the original ROM on. The drive doesn't even boot up
So i think the ROM must be defective or something
I need some help to check this ROM if there is any problems with it and if can extract the information from it to check if it is the original
Many Thanks!
 Post subject: Re: TOSHIBA MQ01ABD050 ROM Problem
PostPosted: Yesterday, 15:52
How can anyone help you if we can't see your ROM dumps?
PostPosted: Yesterday, 21:02
Totally forgot about the ROM
Here it is
https://drive.google.com/file/d/1vDqCz-sKlBXS0Fs57HqLhVYJ5ZyoVx-X/view?usp=sharing
PostPosted: Yesterday, 21:20
The checksums of the CPs seem to be OK. I'm wondering whether there is a problem in the code section. Can you upload the donor ROM?
CPs_00.7z [10.99 KiB]
Downloaded 4 times
PostPosted: Yesterday, 22:45
Here is the donor rom. that the drive was spinning fine and drive gets ready but has different serial number. so i couldnt reach data
https://drive.google.com/file/d/1pmYXlwINne9KuCk_j479kQdO9nJcyQNA/view?usp=drive_link
PostPosted: Yesterday, 22:51
The donor and patient ROMs are identical, except that the donor has an additional 0x110 bytes at the end. :-?
Users browsing this forum: Google [Bot] and 128 guests
